typical problems - Mustang Evolution
Old 08-28-2004, 11:16 AM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
typical problems
i dont kno how many of you kno but i want a manual but i cant buy it new b/c i cant afford one. now i was wondering in a v6 5 spd mustang what are the typical problems that i should look for in the car. im looking for one with about 20k on it or less. now from my experience with my car it should be very reliable but i just want to kno is there any thing i should be looking for?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 08-28-2004, 11:59 AM   #2
unusual sounds in the diff, unusual sounds when you shift, check the clutch is not worn like its not way to soft, unusual engine sounds
Old 08-28-2004, 12:59 PM   #3
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
yea look for sounds you wont want one that was reamed on every day
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 08-29-2004, 05:33 PM   #4
ok thanks guys. is it normal for these cars to be hard to shift into 5th and reverse? i have driven a couple of them and all of them i have had a hard time gettin in to 5th and reverse. thanks
Delta Sigma Phi
www.DeltaArmsCo.com
Old 08-30-2004, 06:55 AM   #5
Danger Dude's Avatar
The stock shifter sucks major league but it should still shift into gear.
Old 09-03-2004, 07:20 PM   #6
MonteCitan's Avatar
I PDI at least one mustang per week - every single manual trans one has been harder to shift into 5 than the other gears, and stiff into reverse
Old 09-03-2004, 08:38 PM   #7
97Stallion's Avatar
It's shouldn't be hard to shift into them, but sometimes you have to go into a gear to get into a different gear. Like when I go into reverse, I go into 5th first, it lines up the syncros. But when you first sit in the car, push on the clutch pedal and see if you feel any play. If you do it may need some adjusting. If you adjust it, and there's no slack it should shift like a dream. Sometime this slack causes the clutch to not disengage 100% and it takes a while to shift when the RPM's are high. So if you're trying to shift from 1st to 2nd at 5000rpms, you might have too much slack in your cable, or the T/O bearing is screwed, or you have internal tranny problems.
Living one day at a time!
My typical conversation with a GT owner... DarkShadow The Bar 30 08-03-2006 05:38 AM
Typical Ricer lingo...... Cajun JungleBoy The Bar 3 08-02-2006 08:38 PM
a/c problems Warfire80 1996-2004 Mustang GT 6 11-29-2004 04:52 PM
More Problems Toxinz The Bar 4 05-01-2004 10:09 PM
typical ricer Suprman Pre-2005 V6 Mustang 4 11-18-2003 10:56 AM
11:52 PM
