*DUW* Adaption of supercoupe m90 twinscrew to splitport - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 07-16-2003, 01:36 AM   #1
tire's Avatar
tire is unknown around these parts
Send a message via AIM to tire
the to-be manufacturer wishes to keep a generally low profile until his prototype is built on a stock v6 (non supercoupe) bottom end and the legalities of his business are worked out. i'm in line to be the first actual tester of this design. i think there are a couple different versions here i'm posting.
diagram of blower:
i'll initially be running low boost until i can upgrade my engine to withstand anything above 7-8psi. the splitport heads/intake on the 99+ v6's flow much better than the 94-98 v6's and the 99+ v6's won't be making nearly as much boost because of its vol. effeciency. (boost = the difference in flow rates between the blower and the engine) splitports have much higher volumetric efficency so they flow much better then the SC heads, so you'd have to overdrive the hell out of a stock eaton m90 blower to make that much boost. however, generally speaking, more boost and less flow is similar to less boost and better flow. they are generally inversely proportional. it'd be good to keep the better flowing intakes and heads and apply the blower on top of that than reverting to 94-98 heads and intakes and convert a 190 hp 99+ v6 to a 150 hp 94-98 v6. that's what this whole post is about.
pics:
the key is the adaption between the lower splitport intake and the blower. there have been many suggestions, some more costly than others.
i'm interested in a water-air intercooler and may have it mounted where the battery is now, or maybe elsewhere under the hood. here is the diagram:
pics of a SC blower, fyi...
pictures with inlet plenum/piping/TB on the left.
i may take the stock SC MAF if i am going to use the stock SC injectors (30#ers i think).
a probably parts list in addtion to the adaption kit:
-austin
tire is offline
Old 07-16-2003, 01:38 AM   #2
tire's Avatar
oh and with the top mounted design the hood clearance may need to be about 2" higher. i'm planning on getting a cowled scoop to be molded into my stock 99 cobra hood to add clearance.
tire is offline
Old 07-16-2003, 08:47 AM   #3
Monkey's Avatar
Monkey is unknown around these parts
looks very thurough. looks to be a lot of work though. good luck w/ it and let us know about updates
Monkey is offline
Old 07-23-2003, 01:21 AM   #4
tire's Avatar
looks like it may be one more month before the parts start coming in and things start happening. the plans are being revised a lot so who knows for sure when this will happen.
anyone got an 36#'ers they want to give me? :
tire is offline
Old 09-22-2003, 03:53 PM   #5
RGR
RGR is unknown around these parts
Send a message via AIM to RGR
Looks good so far!
How is everything going?
I need an update and
of course you will need
that cam soon, best to get
it ordered soon too, and
figure out springs and such...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline
Old 09-22-2003, 06:59 PM   #6
tire's Avatar
RGR, i PMed you on v6power.
tire is offline
Closed Thread
supercoupe m90 supercharger 3.8boii Pre-2005 V6 Mustang 4 04-19-2010 10:48 PM
Supercoupe V6 Engine matthews.stang Pictures and Videos 13 04-24-2007 10:19 PM
splitport 98Ga Pre-2005 V6 Mustang 1 12-18-2006 10:30 AM
Supercoupe Build Up Black95GT Pre-2005 V6 Mustang 11 01-03-2004 10:01 AM
Supercoupe sc on 2002 3.8 bluestang44 Pre-2005 V6 Mustang 14 12-19-2003 06:46 PM
02:11 AM
