coolant leak - Mustang Evolution
Old 09-01-2004, 12:27 AM   #1
Exclamation coolant leak
What could i do to seal a coolant leak from the manifold which is cracked while I get a new one?
thnx
josh97gt is offline   Reply With Quote
Old 09-01-2004, 12:45 AM   #2
01mineralgrey6's Avatar
um...getting a new maniflolds about all i can think of...may wanna try some JB weld or something?? i don't know, others will chime in. Welcome to the site btw
-Tony
'99 cobra 'vert
Old 09-01-2004, 12:49 AM   #3
I asked for something "WHILE" I get the new manifold. Whats JB weld?
Old 09-01-2004, 01:40 AM   #4
I liek gramer
WhiteStang99's Avatar
you might have to explain that. They may not have JB Weld in China.
Old 09-01-2004, 01:41 AM   #5
I live in texas
Old 09-01-2004, 01:43 AM   #6
I liek gramer
2:
Anyways, google is ur friend. JB Weld is something that reacts to create a weld-type of bond, usually between two metals. It basically creates a "weld" (which I'm assuming you know is) by mixing two chemicals and allowing them to cure.
Old 09-01-2004, 07:11 AM   #7
97Stallion's Avatar
JB weld is an epoxy based adhesive. When you mix the 2 parts, a chemical reaction takes place and it'll form a tempory bond. This stuff is ok, not the greatest. Also you need to give it about 24 hours for it to fully cure. You can pick it up at just about any auto parts store. And where exactly is this crack? Do you have pics for us?
Living one day at a time!
Old 09-01-2004, 11:38 AM   #8
I've put jb weld on a radiator crack before..it couldn't handle the heat and ended up busting again in the same spot through the jb weld..just my 02cents and personal experience for ya
bad coolant leak jmachleit 1979-1995 Mustang GT 8 01-13-2010 05:31 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-28-2008 12:54 AM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 09:40 PM
coolant leak inside car Racin02GT 1996-2004 Mustang GT 8 06-19-2006 07:19 PM
exhaust leak mustangruss Pre-2005 V6 Mustang 22 12-10-2005 09:26 AM
08:18 PM
