toque converters - Mustang Evolution
Old 09-01-2004, 08:17 PM   #1
Send a message via AIM to charkelly9
toque converters
Hey guys i got offered this from edgeracingconverters.com
Depending on the application, combination and desired stall math this can be configured in our "Mild Street Edge" series with stall math as high as 2600rpm for 374.50, or the "Street Edge" series with stall math as high as 5500 RPM (your choice ) for 565.00. Both have the upgraded "high carbon" friction lock up and come with a one year warranty and our 100% money back satisfaction guarantee.
Does this seem like a cheap converter? Would you go with a PI stallion ? thans for your imput
charkelly9 is offline   Reply With Quote
Old 09-01-2004, 08:20 PM   #2
i have never bought a converter since i drive stick but its a good price i just dont know about that brand
Old 09-01-2004, 08:26 PM   #3
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
i have always been told to go with the stallion tq converter, thats were im going prolly. i would not go with over a 3k stall on a stock car thats for the streets.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 09-02-2004, 02:54 PM   #4
toque
1998Gt blk 5spd, 2003 PI motor, mac long tubes, bbk o/r h-pipe, mac afta cats, mac cai
ScottEvil is offline   Reply With Quote
Old 09-02-2004, 04:27 PM   #5
Monkey's Avatar
Edge converters are fine and all, but PI is world-renoun and everyone knows them. Edge is okay, not as good as PI. if you get the Edge, then get the street one and get a 2800 stall if you have a 99+ and a 2600 if you have a pre99
Old 09-02-2004, 04:30 PM   #6
yeah the street edge sounds good the other one is sure to make you into a gas gussler
Old 09-02-2004, 06:15 PM   #7
97Stallion's Avatar
As much as I would like to help, i have no clue since I drive a stick. I think Corey would know. He should be in here soon. You can also check out his sig. That's what I would do.
Living one day at a time!
Old 09-02-2004, 06:18 PM   #8
97Stallion's Avatar
Or, i could just post it for you. I don't see a TQ converter in there anywhere, so you might need to just PM him.
Corey
Sponsors: www.extremeeffect.com www.rpm-mustangs.com www.autobadges.com
Laser Red 98, RPM HP Heads, RPM 216/225 Cam, Polished RGR Stage 3 Intakes, 19# injectors, 60mm TB, Flex spacers, Interceptor 4R70W w/ transgo shiftkit, F-4 Fordchip, MSD wires, UDP, MAC CAI, Red vacume hose mod, Powdercoated Laser Red Valve covers w/ Metco chrome breather oil cap, MAC O/R H Pipe, Custom Duals w/ Dynomax mufflers, 3.73 & Tlok, Bullitt/ Tokico struts & shocks, C springs, Front & Rear Cobra sway bars, Steeda STB, Steeda SFC, UPR Shark Billit C&C plates, 98 Cobra Rims, 99 PBR dual piston Red Calipers w/ SS brake lines, Power Stop front slotted rotors, Ultra clear headlights and Ultra clear corners, Ultra clear foglights, 35th anniversary gauge cluster bezel, Auto meter Gauge bezel, emblems by Eval.
IN GOD I TRUST
Old 09-02-2004, 07:14 PM   #9
slvr2000stang's Avatar
Brandon,
How come you keep saying 2800 for a 99+?
Just wondering.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 09-02-2004, 07:23 PM   #10
Monkey's Avatar
Because they have a slightly higher redline than the single ports did. Plus with the 3.27s stock instead of the 2.73s, their peak tq is moved up slightly. Since it is a 2800 stall (which moves break stall to about 2200-2300). The SPI engines can break stall higher and then use their lower (numerically higher) gear ratio to makeup for the higher stall and lockup rpms.
EDIT: with the single port engines, you want the tq to be lower in the power band because of the 2.73s and the 40 less bhp and with the same tq, you want it on tap at all times.
Old 09-02-2004, 07:24 PM   #11
Just wondering since most of us have the 3000 on a 99+
2000 Vert 4R70W
Old 09-02-2004, 07:27 PM   #12
Monkey's Avatar
3000 works, but I don't like suggesting anything higher and thus 200 rpms less works well
Old 09-02-2004, 07:37 PM   #13
Good reasoning.
2000 Vert 4R70W
help with torque converters and shift kits charkelly9 Pre-2005 V6 Mustang 6 08-26-2004 03:45 PM
01:46 PM
