tq converter and a set of 4.10s - Mustang Evolution
Old 09-01-2004, 08:31 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
i had a couple quick questions. 1) if i got both these thing and the bolt ons where would i land on a 1/4 mile? 2) im not to worried about my top end but my questions is will my car feel like its lost power up top, im saying about the 60-80 ot 85 time? 3)and how much suspension stuff will i have to do to hook off a line?
thanks for all the help
edit the tq converter will be a 3k stall from PI
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 09-01-2004, 08:37 PM   #2
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
id like to say low 15s maybe very high 14s
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 09-01-2004, 08:39 PM   #3
Falcon's Avatar
i dunno why you would lose top end unless you raised your gears?
-Derek
1999 Trans Am WS6
Old 10-12-2004, 09:59 PM   #4
fastmustangs1's Avatar
Well with a tq converter and gears the car will defintaly launch a lot quicker off the line. But upgrading the suspension really works great as well. It will help with transfering the weight to the rear tires, eliminate wheel hop for better traction. I would do subframe connectors, shocks/springs, and also lower control arms. And also a softer tire for improved traction the factory tires suck!
Matt 2001 moded V6.
fastmustangs1 is offline   Reply With Quote
Old 10-13-2004, 08:05 AM   #5
with a tq converter and a tune to set shift points correctly along with a jerry mod and 4.10s you should shave a massive amount of time off your car, the gears along will do .3 tenths or more with those mods i would say a low low 15 if you can get some sticky tires and a little suspension and cut a 1.9 or better you should be able to do 14s perhaps. it depends on the tq converter and alot of this and thats, but with all the bolt ons and a tq converter, gears, tune to set shift points and all other stuff you should be able to do high to mid 14s with good launches.
Old 10-13-2004, 07:19 PM   #6
Monkey's Avatar
a torque converter will take off 0.5-0.6sec off your ET alone and then gears about .3. So that will be almost 1.0sec off your current ET.
Old 10-13-2004, 08:09 PM   #7
well heres my goal, im thinking between 4.10s(t-lok), a PI 3000 stall tc, correct shift points and firmsness, and a good bit of suspension work and some sticky tires and the bolt ons im hoping for a 14.5 after im good. now 4.10s AND the limited slip make up to .5 off my e.t right? and im guessing the gears are just .3 or am i mistaken? i kno this is not and exact science but im just wondering.thanks
Delta Sigma Phi
www.DeltaArmsCo.com
Old 10-13-2004, 11:54 PM   #8
Monkey's Avatar
no, since you have a 99+, you already have 3.27 gears so 4.10s and t-lock will only take off about .3 maybe .4 off your ET. It will take off .5 off a pre99 though
Old 10-14-2004, 04:38 PM   #9
o ok thats make sense monkey, thanks. how hard do you guys think it would be to get this car to about a 13.9? other then a blower and a 4.2 and nitrous? is it possible?
Delta Sigma Phi
www.DeltaArmsCo.com
Old 10-14-2004, 05:19 PM   #10
since you are starting life with a 16.0 in an auto... gears/tlok/boltons/tq converter/jerry mod with chip to calibrate shift points and all that you should be capable of doing 14.9s and then some pretty easy... with out heads/cam/intakes i dont see you doing 13s (or n20, power adder, etc)
Old 10-14-2004, 05:30 PM   #11
my end goal is a 13s n/a auto.
I'm at high 14s with a ****ty 60'. 4.10s should help my 60' and get me mid 14s. then when I get my new heads/cam I go for 13s n/a.
Its very hard with an auto. I've already gained 8-9mph over my stock 1/4 runs...and that already impressive.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 10-17-2004, 09:11 AM   #12
is there any way to be able to plant this power well? im guessing between 4.10s and a PI 3k stall TC i would have massive amounts of wheels spin off of any line and i dont really want that. would a set of LCA. springs, shocks and struts helps this much or am i just going to have to deal with the smoke . my thought is if i can reduce the spin i can get a really really hard launch.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 10-17-2004, 10:05 AM   #13
Thumbs up
Hey Oaktonarcher,
Yes springs struts and LCA's would really help the weight transfer and traction at the drag strip. They would plant the rear tires for better launch.
Matt 2001 moded V6.
Old 10-17-2004, 10:02 PM   #14
tires would help more than anything.
Get some DR's with a nice sidewall and dorp the pressure. I dead-hook my 255/45/16 Dr's with a relatively short burnout @ 22psi
New Hottness
1999 V6 5-speed
Wrecked
Old 10-26-2004, 09:50 PM   #15
Kiljosh's Avatar
Stangin, what mods you have currently? You seem to be wanting to do the same exact thing I want, build a beast of a NA motor, then save up and get a charger
2 V6 in the 10s 2007STANG Pre-2005 V6 Mustang 13 07-07-2009 08:45 PM
First 2010 in the 10s SVTCOBRA 2011-2014 Mustang GT 5 06-29-2009 10:12 AM
4.10s with a blower sporter 2005-2010 Mustang GT 11 06-01-2007 09:40 PM
Got 4.10s in today blownsix The Bar 7 12-18-2005 03:13 PM
4.10s are officially in!! tire The Bar 5 07-14-2003 11:50 PM
09:33 PM
