Quick Question - Mustang Evolution
Old 01-19-2009, 10:40 PM   #1
Greywolf's Avatar
Region: Nevada
Quick Question
I'm thinking it's time to install the 4.10 gears and a tlok. I have 2 questions in that regard.
1. Where would you recommend I go to get them
2. About how much should I expect to spend to have them installed.
2007 V6 Mustang w/ Pony Package. Performance Mods - 2.25 custom aluminum catback exhaust with a Magnaflow muffler, AirRaid cold air intake, drilled and slotted rotor's front and rear, SCT Programmer, Ford Racing Tlok, Motiv 4:10 gears, LFP underdrive pulley
Greywolf is offline   Reply With Quote
Old 01-20-2009, 06:16 AM   #2
Herbstang's Avatar
Re: Quick Question
Check your local speed shops out. Maybe one of the vegas members will jump in and recommand a shop .Gears install can run from 400.00 to 700.00 depends on the shop and don't go with the lowest price you get what you pay for
Old 01-20-2009, 07:27 AM   #3
Re: Quick Question
dont skimp on this install as doing it wrong can cost you much more than just a redo as once the gears get worn wrong.. you have to buy new ones.
Basically if the shop tells you when they install them they set the backlash, pinion crush sleeve, gear wear pattern and the likes then they know what they are doing, you dont just bolt them up and go.
Get a warranty (here is the tricky part for some) IN WRITING stating that you are covered for X miles from whine or breakage or any other issues. If one of the little bolts around the ring gear comes off say bye bye to the entire rear end.
Old 01-20-2009, 02:56 PM   #4
Greywolf's Avatar
Region: Nevada
Re: Quick Question
Good to know guys and thanks. I'm gonna go with American Muscle to buy the parts.
Old 01-20-2009, 03:05 PM   #5
Re: Quick Question
let us know how it all goes, if you can get install notes and pictures you can turn it in on the article section (PM Brent) and make some good cash on it!
Old 01-27-2009, 11:19 AM   #6
Greywolf's Avatar
Region: Nevada
Re: Quick Question
So this one goes out to any and all Vegas members. Anyone of you guys know someone trustworthy and good that might be able to help a guy out?
quick question durtyred69 1979-1995 Mustang GT 5 01-13-2011 11:15 AM
quick question jonbean Pre-2005 V6 Mustang 1 07-16-2009 02:48 PM
i got a quick question yoast88 1996-2004 Mustang GT 3 01-16-2009 03:26 AM
quick question ttpancakes The Bar 8 12-11-2004 08:21 PM
quick question Thomas91169 The Bar 9 03-19-2004 12:53 AM
08:45 AM
