410 gear speedo question - Mustang Evolution
Old 07-16-2003, 10:26 AM   #1
In another post, someone mentioned a ERA thing from Abbott to correct the speedo and odometer issue. What is the ERA thing and where can I get one? All 3.8 mustangs deserve a 410.
1994 vert. UD, Mac headers, h-pipe, exhaust, 410,tlok
Freds3.8 is offline   Reply With Quote
Old 07-16-2003, 10:45 AM   #2
tire's Avatar
Send a message via AIM to tire
i'm not sure where to buy a speedo gear, but are you 100% sure which one you need? go to v6power.com and go to tech or articles section and find the right speedo gear size there if you don't already know. sorry, i have 4.10s going in a 00 5 spd so i really don't know about 94-98's.
tire is offline   Reply With Quote
Old 07-16-2003, 11:50 AM   #3
Danger Dude's Avatar
you can get the 23 tooth gear at Ford or GEF Racing or anyplace that sells gearsets. As for a a speed cal device on 94 98 they only work for 5 speeds
Corey
Old 07-16-2003, 11:51 AM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Check out the Steeda website.
They have all the gears, and which ones you need.
Rellik is offline   Reply With Quote
Old 07-16-2003, 07:28 PM   #5
Just ordered from Steeda. Thanks
Old 07-16-2003, 07:42 PM   #6
np
8)
Old 07-16-2003, 08:08 PM   #7
Monkey's Avatar
speedcal doesnt work on the pre99s. our trannys arent speedo electronically controlled
Old 07-16-2003, 08:20 PM   #8
Sorry Monkey Man but you are WRONG O
Look at this and tell me again
http://secure.50resto.com/product1.cfm?SID=1&Product_ID=361&Category_ID=145
8) 8)
Corey
Old 07-16-2003, 09:00 PM   #9
Monkey's Avatar
Description
The speed calibrator is used to correct electronic speedometers in 1994-01..
key word.. electronic speedometers
ours isnt electronic. the GTs and cobras had them. v6s got the short end of the stick
Old 07-16-2003, 09:02 PM   #10
actually it does work on 98 V6 cars I dont know about others
Corey
Old 07-16-2003, 09:02 PM   #11
damn if matt was here iam sure he would know.
get in here matt!!
Old 07-16-2003, 09:08 PM   #12
We dont need Matt cause it is true if you dont believe me call or contact them by email remember it only works with 5 speed cars
Corey
Old 07-16-2003, 09:16 PM   #13
Monkey's Avatar
http://www.3.8mustang.com/forum/showthread.php?t=22907&highlight=speedcal midway down posted by tbennett: pre99 speedo's=controled by speedo gear
99+ speedo=EEC controlled
oh, and also Dallas Mustang owns the patent on it, and i dont trust anything about that store. been in there many times, and seen the work they do. looks like all noob work except on cars that they sponsor.
**still trying to find where matt says it works or doesnt work**
Old 07-16-2003, 09:23 PM   #14
Did I say it was good no I did not, I also did not recommend buying it. But the fact is it is available and I was just trying to inform but by all means go ask Matt
Corey
Old 07-16-2003, 09:28 PM   #15
Monkey's Avatar
Corey
fair enough. i see your point. if it works, great, the sites say they work, so ill go with you on this. but i still wont ever tell people its an option for pre99s. just my pig-headedness
Old 07-16-2003, 09:33 PM   #16
Hey Brandon I dont promote it but Freds3.8 bought up something made by Abbott and just thought about speedcal. I have never heard much good about the product either a very hit and miss kind of product. Like Diablo MAHAHAHAHAHAAHA
Corey
Old 07-16-2003, 09:35 PM   #17
Monkey's Avatar
yeah, i havent heard anything about the Abbot. in fact, i should do some research about it cause i dont even think its like the speedcal. i think its something totally different. but before i post about it, ill do my research
Old 07-16-2003, 09:39 PM   #18
8)
Old 07-16-2003, 11:24 PM   #19
Zim
You want to **** me?
Zim's Avatar
yeah figure out the deal with that abbott thing because im tired of racking up all these false miles
I like toys
Old 07-17-2003, 09:45 AM   #20
These false miles really suck.
Old 07-17-2003, 09:50 AM   #21
Doesnt just the speedo gear just fix the false miles?
Old 07-17-2003, 09:54 AM   #22
I hope it will. If so it is a really cheap fix.
Old 07-19-2003, 08:30 PM   #23
Send a message via AIM to mattsdrag95
get in here matt!!
hmm i guess i should come on here more often huh?? hehe sorry guys.
to be perfectly honest, i do not know much about the speed cal and such products..i've always just bought the speedo gear(if applicable) and dealt with it being a tad off if that's the case.
all the mustangs i know of till 99 have a speedo gear, regardless of tranny..the autos however are limited by what speedo gears they can buy.
by looking at that speedcal, it looks like it replaces your stock sensor and reconnects to the wiring harness with something new..
eh, it's an alright idea for someone to try and make a buck if you ask me.
for a pre99 car i wouldn't even think about it because a 15dollar speedo gear will fix your problem most of the time within a 5% difference.
i can only see that being used on a 99+ if the person only wants to correct the speedo and doesn't want to bump redline, or remove top speed and the other benifits of a chip.
other than that i think it's a waste.
i had a 17tooth gear in my ranger that had 3.08s and i just put in 4.10s.
the speedo was off by more than 40mph...then i bought a 23 tooth today and now it's almost perfect..i haven't been able to tell acurately if it's dead on, but it's very close, which is more than fine for me.
if you want my honest opinion, and i'm not shooting anyone, or anything down, i would just go the normal route. these are simmilar to the companys that make the product you plug into your maf to "adjust" for different injectors...it's quite iffy. you shouldn't have to buy a special box just to calibrate your speedo when it can be done quite simply otherwise..
but just as monkey said...if you buy it and it works, that's great. just because i'm not going to take the risk on a product that hasn't been around really long, and i haven't heard much about, doesn't mean you don't have to..feel free to buy what you wish..it is your car after all
matt
http://images.cardomain.com/member_i.../387560_89.jpg
95 ranger splash, 4.0 5-speed.
cold air, 8.8, 4.10s/t-lok, AR torq IIs and 295/50 rubber, custom traction bars w/james duff traction bars as well. flowmaster exhaust w/turndown.
line lock, 190lph pump, an fuel lines, aeromotive FRP, nitrous system, solid engine mounts, a driveshaft loop, and some 27x14"slicks
1.9 short times
13.989@97mph
257rwhp
359rwtq
mattsdrag95 is offline   Reply With Quote
Old 07-21-2003, 02:07 PM   #24
Installed 23 tooth gear today. Speedo seems to be accurate in the 20's. Between 30 and 50 it is about 6.4 fast and between 55 and 70 it is almost 10mph fast. Odometer still seems to be off. It may vary with speed also. Did not check. Engine still cuts out at 3k rpm. Damn chip.
Another gear question 01 PR RAGTOP 1996-2004 Mustang GT 6 08-18-2008 11:00 AM
Speedo question petreboy14 Pre-2005 V6 Mustang 6 07-30-2006 09:55 PM
Gear question lowflyn Pre-2005 V6 Mustang 8 01-23-2006 08:29 AM
2001 automatic 410 gear replacement DelawareDave Pre-2005 V6 Mustang 16 07-24-2005 03:28 PM
Speedo Gear Brent Pre-2005 V6 Mustang 15 06-23-2004 12:08 PM
05:24 PM
