Code P1443 How to fix it? - Mustang Evolution
Old 09-03-2004, 01:33 PM   #1
Had the car coded a 96 3.8l stock and P1443 showed up. Being new to Mustangs (since it is my g/f car) I did a little research and found this article.
http://www.totally-ford.com/ford/for...ticle-625.html
Now can someone break that down to an unexpirience joe like me? Any pics or Ideas of where are should be looking for sensors, canasters, vaccums and valves?
Thank you,
Neptuno
Neptuno is offline   Reply With Quote
Old 09-03-2004, 08:21 PM   #2
Send a message via AIM to speedyhank
what is it doing?
speedyhank is offline   Reply With Quote
Old 09-03-2004, 08:28 PM   #3
97Stallion's Avatar
Well that code means the IAC (Idle Air Control) valve on top of the throttle body is screwing up. No offense intended, but being you're g/f's car, has she ever changed the air filter? Usually the IAC screws up because it gets full of dirt. She may just need a new one, no biggy. Or you could take it off and blow in it to see if dirt falls out. Here's a pic, just so you know where it is. It's the blue thing the arrow is pointing to.
Living one day at a time!
Check engine code- p1443 embecker Pre-2005 V6 Mustang 7 05-12-2014 12:22 AM
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 08:32 PM
CODE PULLED P1443? BILLFORD01 1996-2004 Mustang GT 13 08-06-2009 11:20 AM
What is the fix for this DTC code? PureVenom General Mustang Discussion 4 08-20-2008 06:30 AM
07:03 AM
