Supercharging and replacing rear axle and gears for my mustang 2008 - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 01-21-2009, 12:05 PM   #1
bmx_20055 is unknown around these parts
HERE IS THE SUPERCHARGER KIT Mustang X-CHARGER 4.0 SOHC HI-PO PLUS (3.0 pulley 6-7PSI) with tuner
The Hi-po Spec X-CHARGER uses a unique Cold Air Intake system with integral 84mm Mass Air housing, conical K&N airfilter and 3.5" ID rubber inlet hose PRICE $4,395.95
AND THE SUSPENSION IS 8.8" Rear axle assembly, Mustang V6 '05-'08 3.73:1 ratio with ABS and Trac-Loc (Cobra Pinion Flange) PRICE $879.99
FOR A TOTAL $5275.95
WOULD YOU SAY THIS IS A GOOD DEAL CAUSE THE AD FOR THE SUPERCHARGERS SAY YOU DONT HAVE TO UPGRADE ENGINE SINCE ITS ONLY 6-7PSI BUT IT SAYS ANYTHING ABOVE YOU REQUIRE MORE MODS
bmx_20055 is offline
Old 01-21-2009, 12:49 PM   #2
jimmy_beaner's Avatar
jimmy_beaner is unknown around these parts
Re: Supercharging and replacing rear axle and gears for my mustang 2008
I'm unfamiliar with that blower.
jimmy_beaner is offline
Old 01-21-2009, 01:01 PM   #3
ITS FROM EXPLORER EXPRESS THEY DID A SHOW ABOUT IT ON STREET LEGAL TV SUPPOSE THIS IS A GT KILLER
Old 01-21-2009, 01:33 PM   #4
1234's Avatar
1234 is unknown around these parts
Is there a warranty on the supercharger?
If so i would say that is a good deal for the parts being they are brand new.
1234 is offline
Old 01-21-2009, 02:10 PM   #5
Renegade 800's Avatar
Renegade 800 is unknown around these parts
Yes it has a warranty. Nice detailed install sheets too.
"SUPERCHARGER AND BY-PASS VALVE LIMITED WARRANTY
Magnuson Products
1 YEAR LIMITED WARRANTY
Eaton Supercharger Division
Magnuson Products warrants and will repair or replace, at their option and after inspection in
their facility, any new item produced by Eaton or Magnuson found defective by means of material
and/or workmanship for a period of one year from invoice date. This limited warranty does
not cover products which fail because of accident, alteration, misuse, neglect, racing, improper
installation, abuse, or when used in applications for which they were not designed or
approved. Removal, installation, transportation, labor, inconvenience, damage of other components,
personal damage or injury and any injury or liability to other persons or property are not
covered under this warranty. Magnuson Products, Z Doctor or Explorer Express shall not
be liable for any and all consequential damages occasioned by the use of this supercharger or
by breach of any written or implied warranty pertaining to this sale in excess of the original purchase
price.
Model # M90 Serial #__________________ Date purchased _________________"
Renegade 800 is offline
Old 01-21-2009, 02:51 PM   #6
1234's Avatar
Id say go for it.
1234 is offline
Old 01-21-2009, 02:59 PM   #7
I will thanks all for your opinions just wanted to make sure that this was a good deal
Old 01-26-2009, 10:23 AM   #8
The Darkside's Avatar
The Darkside is unknown around these parts
looks good. even though i dont know about that blower, it it has a warrenty i say go for it.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline
Old 01-26-2009, 11:49 AM   #9
hottcobra's Avatar
hottcobra is unknown around these parts
well it's looks like it's made by Eaton but sold under a diff. name
hottcobra is offline
Old 01-26-2009, 12:42 PM   #10
Herbstang's Avatar
Herbstang is unknown around these parts
You got it !!! Ca kit uses a GT air box. HiPo kit uses a CAI with K&N filter and a 2.8 pulley
here's a dyno clip Mustang V6 X-Charger Dyno Run - Truveo Video Search
The California Spec X-CHARGER uses a stock Mustang GT airbox with 80mm Mass Air Supernatural Performance
Not sure about that rear !!! Don't forget about upgrading suspension,brakes,tires
Mods-K&N CAI , True Dual Flowmaster 40,BBK Ceramic Shorties,3.73 ,T-Lok, 25% UDP, 3/8 Phenolic Intake Spacer ,Steeda Tri-ax, SCT Chip/Dyno Tune
Herbstang is offline
Old 01-29-2009, 05:38 PM   #11
stangaroo's Avatar
stangaroo is unknown around these parts
I'm skeptical about the "GT killer" phrase here, This thing ends up producing 5 more wheel HP than the GT and comparable torque as well, between the weight advantage and this tiny amount of HP, is it really going to KILL a GT or just very slowly pull away from it?
stangaroo is offline
Old 01-30-2009, 01:40 PM   #12
they gota say somthing to sell it! gt killer it is lol
i bleed Race fuel!
Old 01-30-2009, 02:28 PM   #13
1234's Avatar
^^Couldnt of said it better myself.
1234 is offline
Old 01-30-2009, 02:30 PM   #14
hottcobra's Avatar
just like the Nissin GT-R was gonna kill everything on the street. It only kills it's own trannys
Old 01-30-2009, 02:34 PM   #15
PureVenom is unknown around these parts
Uh oh, now you've done it...Nates going to get you for that one...
PureVenom is offline
Old 01-30-2009, 02:38 PM   #16
hottcobra's Avatar
don't make me have hitler call Nate and tell him what he thinks about the GT-R
Old 01-30-2009, 02:40 PM   #17
^^^ I already posted that video...u-2-slo now
Old 01-30-2009, 02:48 PM   #18
hottcobra's Avatar
I know that. that's what I was making a reffernce to
Old 02-01-2009, 09:05 AM   #19
Titus Wadicus
svtlx's Avatar
svtlx is unknown around these parts
an 8.8 rear end for 6-7lbs...r u serious. 3.73 swap with a good trac-lok, i can see that. but a full 8.8 swap is a bit of over kill unless you are plan'n on run'n 14lbs. or more. im run'n 11lbs. on a 308c.i. with a 7.5 and no problems. it's just my opinion. its like put'n an 8pt cage in a geo metro...sure it's great to have, but do u really need it??? with only 6-7lbs. i dont think you are anywhere near pushing the performance envelope of a 7.5 unless you are planning on turning it into a 500+hp v6. im sure someone will correct me if im wrong.
svtlx is offline
Old 02-05-2009, 06:33 PM   #20
Joe_SHO's Avatar
Joe_SHO is unknown around these parts
They're talking about Escort GT's. If you're really good on the stick, you might even beat the occasional Probe GT.
Joe_SHO is offline
Old 02-05-2009, 07:01 PM   #21
DaDant!'s Avatar
DaDant! is unknown around these parts
wow... joe.. do you ever have anything nice to say? all the posts ive read ur being a smartass. but oh well i dont really care.
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline
Old 02-05-2009, 07:30 PM   #22
Titus Wadicus
svtlx's Avatar
im not big on bash'n ppl's dreams, but i have to agree the term "gt killer" may have been used a bit too loosley, at least at the current boost level.
svtlx is offline
Old 02-06-2009, 07:34 AM   #23
1234's Avatar
Maybe they just didnt specify which model year GT.
1234 is offline
Old 02-06-2009, 09:47 AM   #24
Titus Wadicus
svtlx's Avatar
you are right, i suppose a stock '83 would get a mud hole stomped in it. i think it should been a 14-15lbs. kit to throw that phrase out there.
svtlx is offline
Old 02-06-2009, 11:14 AM   #25
1234's Avatar
Exactly.
1234 is offline
Old 02-07-2009, 09:06 AM   #26
StangPride is unknown around these parts
I was interested in this set up myself. There are alot of guys on mustangforums.com that have the X Charger set up. There suppose to be making about 300-305RWHP and they say its instant. So Im sure a stock 05+ mustang GT it would beat. Then again a GT with bolt on mods, prolly wouldnt. There arnt alot of great numbers with it though. There is alot of talk online about a Intercooler for it so that would be great. Just google the X Charger and youll see all kinda talk about it and like I said the guys on that site have alot of input.
If I get mine, Im getting it through Steeda cause I dont like the K&N intake. As far as a 8.8 rear. I dont think you would need it. There are a couple guys with older V6s with cams,heads, turbos pushing over 400hp with 7.5, t-lok and gears and there ok.. Unless you have that extra money I wouldnt worry about.
StangPride is offline
Closed Thread
Replacing the rear end Lukesta Pre-2005 V6 Mustang 2 05-21-2010 04:47 PM
Replacing stock motive gears to new? NavyGT99 General Mustang Discussion 7 08-12-2008 07:16 AM
09:04 AM
