what to do next???? - Mustang Evolution
Old 09-05-2004, 01:40 AM   #1
what to do next????
hi, i have a 2002 v6 mustang with dual exhaust, and a k&n. i do not really know what i should do next.i am just looking for some more power...most people that i have talked to say that i should get a chip, and that it will help the most. if so, what kind should i get??? what about headers? or underdrive pully's??? thanks a ton for any help!
kyle
k8338j is offline   Reply With Quote
Old 09-05-2004, 01:52 AM   #2
gears and t-lok
Old 09-05-2004, 01:55 AM   #3
i may sound like a dumb, but what is a t-lok??? and would gears mess with warranty? thx again
Old 09-05-2004, 02:21 AM   #4
Chip will not help you much with your current set up
T-Lok = Traction Lok
Gears will unlikely cause any problems with your warranty.....
I would recommend 4.10 gears for Auto and 3.73 for Manual
You will however need to get a chip if you change gears to correct your speedo and remove your speed limiter
Old 09-05-2004, 08:25 AM   #5
97Stallion's Avatar
if power is what you're looking for you're best bet is an UD pulley. It takes very little knowledge mechnical knowledge to do this mod. Anyways, I would get this and a CAI, it will add some bling bling under your hood and you'll pick up some power. You will have somewhere around 205hp with these added.
Living one day at a time!
Old 09-05-2004, 09:45 AM   #6
He will notice 4.10's more than he will notice a Underdrive pulley imo
Old 09-05-2004, 09:53 AM   #7
97Stallion's Avatar
True, but it seems like this guy is on a budget. If he was to buy gears, he should get a t-lok also, so then to get them installed is gonna cost him a pretty penny. This way he can pick up some more power for cheaper and his stock gearing isn't too shabby, better than my stock 2.73's.
Old 09-05-2004, 12:22 PM   #8
instead of getting a chip for your speedometer he can get a speed cal right?
Old 09-05-2004, 12:25 PM   #9
Yes but if he changes gears he is going to need a chip anyways so you might as well use that to correct both
Old 09-05-2004, 12:31 PM   #10
so the speedcal for your speedometer and the chip to raise the speedlimiter
Old 09-05-2004, 12:33 PM   #11
97Stallion's Avatar
No, if he uses the speedcal to fix his speedo readings, he'll still need a chip to raise the speedometer limit. So instead of wasting money for two products, just have it all done in one, via a chip.
04:05 PM
