4.2 swap sorta - Mustang Evolution
Old 09-05-2004, 09:40 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
4.2 swap sorta
well as some of you might have noticed i have been wanting a manual for a while now, and now i might have a chance of fixing this problem. i want a 4.2 liter out of a ford f-150 and im guessing the trucks are the same as the stangs 99+ has split ports? and im also guessing that the tranny coming off the 4.2 liter is the t-5? my thought was, after the warrenty comes off i can buy a 4.2 liter already attached to the tranny and drop both in at once with out much extra effort. then i would take the obvious clutch pedal set up and the comp out of the truck and swap it in to the stang. o and i would have to change the shifter handle so i dont mess up the roof of my car . but my question is, is there some things i am over seeing in all this? will it just be much much easier to buy a 5 spd and then swap in a 4.2?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 09-05-2004, 10:06 PM   #2
Tbird232ci's Avatar
the intake manifolds for the 4.2 are different, as for the transmission, i have no idea, but the length may or may not be different
im doubting the pedal assembly from the truck would work either
best bet in my opinion is to get all the 5-speed stuff from a stang, get the block, heads, and all that from the truck
Old 09-05-2004, 10:19 PM   #3
could i buy thet tranny and all from a stang and buy the 4.2 from the truck and match them up out side the car and drop them in? how hard is this to do? and would a comp from a v6 stang 5 spd work on a 4.2?
Delta Sigma Phi
www.DeltaArmsCo.com
Old 09-06-2004, 08:23 AM   #4
97Stallion's Avatar
OK, the tranny won't work as far as I know. I'm almost positive it's not a t-5. And the pedals won't work either. As for the engine, it'll drop right in, but you'll have to remember that the 4.2 blocks have knock sensors, and also the only thing different about the intakes is the upper's split port design. you you can just transfer you upper over. And finally if you have the engine out, now would be the optimal time to do a h/c/i swap. With a 4.2 you're gonna want BV heads at a minumum, and get some highly modified intakes so you can use a 70mm TB, and get them ported and polished. Your best bet for the tranny and engine is to find a junkyard, but still expect to bay close to 1000 or more for the items and then about another 1000 for the h/c/i. And then about another 500 to swap them in. So at a minimum, think around $2500-3000.
Living one day at a time!
Old 09-06-2004, 12:38 PM   #5
Tbird232ci's Avatar
yeah, listen to this guy, he knows more about it than i do
Old 09-06-2004, 02:42 PM   #6
i feel stupid but what is a knock sensor? and im not planing on doing this for another couple years. 2 to be exact so i have time to fig all this out and start collecting parts
Delta Sigma Phi
www.DeltaArmsCo.com
Old 09-06-2004, 03:26 PM   #7
97Stallion's Avatar
Ya listen to me!!
Old 09-06-2004, 03:36 PM   #8
97Stallion's Avatar
A knock sensor does exactly what it says. The sensor(s) detects slight vibrations in your engine caused by knocking otherwise known as pre-ignition or detonation. When the sensor picks up these vibrations it retards the ignition timing which means it changes the point in which the spark plug fires to reduce/remove the knocking. They're pretty cool to have, but if you want to keep them working in your mustang, you'll need the f-150's computer.
Old 09-06-2004, 04:33 PM   #9
that sounds sweet. but is there any down sides to having a F-150 comp?
Delta Sigma Phi
www.DeltaArmsCo.com
Old 09-06-2004, 04:35 PM   #10
97Stallion's Avatar
Not if you can tune it
Old 09-06-2004, 05:04 PM   #11
Monkey's Avatar
you'll have to reprogram PATS on the F150 engine. just use the stock ECU. you'll be fine.
Old 09-06-2004, 07:07 PM   #12
97Stallion's Avatar
If he wants to keep the knock sensors he'll need the computer, but if he doesn't want to keep them, he can just tune his car so that his EEC knows he has a 4.2 now and the extra airflow of course.
Old 09-06-2004, 10:08 PM   #13
chips's Avatar
Send a message via AIM to chips
the 4.2 has a m50d tranny
chips is offline   Reply With Quote
Old 09-09-2004, 01:18 PM   #14
Bane-'s Avatar
any est. on how much a 4.2 would cost? im gonna start lookin around soon to get rid of the 3l in my truck for the 4.2 id prally have to buy just as much huh? id luv to get it with a 5spd but who knows how much work that could be, 3l auto to 4.2 5spd D:
Old 09-09-2004, 02:59 PM   #15
97Stallion's Avatar
Well from a junkyard, you could probably get the whole engine for aout $500-$1000. Maybe less, it all depands on the junkyard. But I personally wouldn't pay more than $600 for the whole thing.
Old 09-09-2004, 03:31 PM   #16
timpryor's Avatar
bane if your 3.0 a duratec?
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 09-29-2004, 02:11 PM   #17
Bane-'s Avatar
kinda bringing this back from the dead but owell :p
i think its the vulcan 3.0 im not sure nor can i remember how to find it out again. lol
*edit* found it, another ranger site says that the vulcan 3.0 has been around since 86 so everything 86 and up has it that has a 3.0 in it.
Old 10-05-2004, 07:38 PM   #18
Send a message via Yahoo to plstktnkr2
4.2 parts
for a dual port 4.2 use the heads, crank, and rotating assembly. mustang block is fine so tranny will fit but intake is different ,so "can" it
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 10-06-2004, 08:14 AM   #19
97Stallion's Avatar
You can use everything except the upper intake from the 4.2. If you get a 99+ upper, you're golden!!
Old 10-07-2004, 12:27 PM   #20
Bane-'s Avatar
ive also seen on other ranger boards from me asking about a 4.2 swap that the 4.2 will bolt up to 5.0 trannys (dont know what kind of tranny that is t4/t5?)
Old 10-07-2004, 02:41 PM   #21
97Stallion's Avatar
Yes a 4.2 will bolt up to a 5.0 tranny, but you need a 94-95 tranny and a 3.8 bellhousing. If the tranny is from a 93 or earlier, it'll still bolt up, but they'll need to swap out the input shaft for a 3.8 one. Also the tranny is a T-5.
Old 10-07-2004, 02:53 PM   #22
Bane-'s Avatar
to any 94-95 5.0 tranny will work with the 4.2 just needs a 3.8 bell housing if im understanding this right, how much work would be involved into making a auto to a 5spd, I might start hunting for parts for it and get this swap in gear gonna goto a junkyard when i get some time to look for the 4.2 block, might just build it from the block up.
Old 10-07-2004, 03:58 PM   #23
97Stallion's Avatar
Well to make an auto a 5 speed, you'll need a tranny, and the computer, and wiring. You can flash your computer I suppose since you're gonna need a tune anyways, but i'm not sure if you're going to be able to drive it without a flash. But anyways, your best bet is to get a 4.2 engine and a 3.8 tranny and bell housing. That's how I would go. If you get a 5.0 tranny, they could charge you more for just because it's from a GT. Or maybe you'll get lucky. V6 parts at junkyards seem to be cheaper, even though they have most of the same parts.
Old 10-07-2004, 08:04 PM   #24
Bane-'s Avatar
ok guess im goin 4.2 block hunting and 3.8 tranny hunting sometime soon
btw since my truck is 4wd...should i just get the f150 transfer case or would mine work...prally wont even keep it 4wd after swap (whenever this might be) but hopefully i can get it worked out.
Exaust clip sorta... and pics Vash Pre-2005 V6 Mustang 9 04-21-2006 03:01 PM
Fixed my brakes...sorta Tbird232ci 1979-1995 Mustang GT 4 02-17-2006 09:05 AM
so....my stuff's effed up...sorta tedness The Bar 4 02-11-2006 11:07 PM
Well...a kinda sorta kill Tbird232ci The Bar 4 09-19-2005 05:28 AM
start probleme sorta oaktonarcher Pre-2005 V6 Mustang 2 01-28-2004 10:15 AM
05:03 PM
