new clutch sound? - Mustang Evolution
Old 09-06-2004, 08:52 PM   #1
new clutch sound?
I have a 2000 V6 and recently had a new Spec stage 2 clutch put on it by a very reliable shop. I broke it in for the first 450 miles and everything was fine and just a few days ago the clutch makes a tweetering sound when it's not engages but when its engaged it stops. my old clutch did this becasue the throughout bearing went on it and could this be the same thing or what? it was a brand new clutch and properly broke in and the flywheel was resurfaced.
bigpomps is offline   Reply With Quote
Old 09-06-2004, 10:00 PM   #2
did you use the spec throw out bearing cause thats a big no no. get a ford throw out bearing
Old 09-07-2004, 12:30 PM   #3
yea, its the spec throughout bearing that came with the disc and pressure plate. if i get a ford t/o bearing will i have to get the flywheel resurfaced again? if so should i just go with a billet alluminium one right away since its a pretty penny to get a t/o bearing installed, might as well go all out?
Old 09-07-2004, 01:17 PM   #4
i say get your flywheel resurfaced. if you really want a billet flywheel get it but i wouldnt
Old 09-07-2004, 05:06 PM   #5
would a new centerforce t/o bearing fit the spec clutch fine or is there going to be a conflict with size or anything else?
Old 09-07-2004, 05:24 PM   #6
Old 09-09-2004, 10:54 AM   #7
its the throwout bearing... spec suck even worse than ford... i strongly suggest putting in a new fork arm pivot ball stud and throw out bearing they are CHEAP parts... well worth it. get a good shop to do it that warranties the throw out from ticking for XX miles or so.
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
i don't like this sound, but what is it? Sassa Massa 1979-1995 Mustang GT 10 07-31-2006 11:02 AM
How does this sound? Dom Pre-2005 V6 Mustang 30 09-23-2005 07:36 PM
sound of an s/c oaktonarcher Pre-2005 V6 Mustang 14 04-09-2005 11:16 AM
No sound 97conv6 Mustang Audio & Video 7 01-28-2005 09:15 PM
01:06 AM
