Update! - Mustang Evolution
Old 09-08-2004, 10:37 AM   #1
Send a message via Yahoo to 98GreenStallion
Update!
Howdy, I thought I would drop by and update yall on my project. As yall prolly know im doing a top end swap by RPM! Heres a list of the mods going on in a few weeks (hopefully):
RPM BV heads w/all machine work etc
Cut and weld upper intake (plenum cut and raised to match throttle body)
Lower intake
216/225 Cam
60mm throttle body
Timing chain set
adj harland sharp RR's *edit* (foregot to put these!)
190lph holley fuel pump (already installed)
bbk adj fuel regulator
24# injectors
autolite copper core plugs
MSD wires
SCT chip
CAI (installed)
25% UDP (installed)
True 2.25 duals w/spintech pros (insatlled)
All the parts that arent already installed will be installed all at once by me
Mik is just about done with everything, so I should be recieving my parts perdy soon!
I got a dyno a few weeks ago.
Max power: 140.5
Max torque: 208.9
Thats just with boltons and the pump, otherwise stock.
I will be getting another dyno when the parts are on and running! Hoping for another 100 or so hp/torque outta the new setup!
Later!
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 09-08-2004, 10:39 AM   #2
Lower intake
216/225 Cam
60mm throttle body
Timing chain set
bbk valve covers
24# injectors
MSD wires
SCT chip
CAI (installed)
25% UDP (installed)
Max power: 140.5
Max torque: 208.9
Later!
Cool keep us updated
Old 09-08-2004, 01:09 PM   #3
97Stallion's Avatar
I would can the 24# injectors for some 19#ers instead. I've got way more done than what you listed and my 19#ers are exactly what i need. Otherewise you'll need some major tuning to lean out your overly rich mixture. With the 24# injectors you'll be running about 10:1.
Living one day at a time!
Old 09-08-2004, 01:17 PM   #4
Danger Dude's Avatar
I am in agreement with Rob get some 19#
Old 09-08-2004, 02:27 PM   #5
01mineralgrey6's Avatar
Sweet, definately keep us posted
-Tony
'99 cobra 'vert
Old 09-09-2004, 07:05 AM   #6
Are yall sure? Cause Mik seems to favor the 24# with my setup?
LAst I heard my heads were being flowed last weekend. That and ordering my cam and welding my upper back together. That was a week ago so everything should be about ready to ship this week I hope...
Do yall think the SCT chip will tune me up good??
RDmotorsport
New dyno
Old 09-09-2004, 10:51 AM   #7
what are the stock injectors for 01's i am sure they will be enough for ported and polished heads/intakes/ and a cam with just bolt ons, set up for 3.8 n/a...wouldnt they?
Old 09-09-2004, 11:50 AM   #8
I am running 19#, with 24# you better be getting a tune soon after BY GOD
Old 09-10-2004, 07:04 AM   #9
Im buying a SCT chip from rpm that will be coming in the same time as everything else. That should do the job, but I think with BV's 24# injectors would be better for performance, with the chip of course. Without the chip, my car woulnt run very well after****s...
RDmotorsport
New dyno
Old 09-10-2004, 07:20 AM   #10
Actually it wont make any difference. The 19# and the 24# injectors can deliver more fuel than the car needs. All injectors do is deliver fuel. There is no added benefits to having larger than necessary injectors.
So no there will be no better or worse performance between the 2 on a Single port engine.
Old 09-10-2004, 09:39 AM   #11
97Stallion's Avatar
Also, the reason I wouldn't get 24# injectors is because they're an overkill for your setup and you'll require more tuning to get your setup to run right. You can get just about any injector to run with any setup, but your have to tune for that and I personally would like an injector that I only have to fine tune. With larger injectors you have to start off in left field and where you wanna be is at home plate. And since I'm on the anologies, 19# injectors would atleast start you on the pitcher's mound. I'm just trying to help you out and no disrespect to Mik, but a mail order chip is not the best way to go about it. Dyno tuning is really the only way to do this.
Old 09-10-2004, 11:11 AM   #12
total agreement
Old 09-10-2004, 11:46 AM   #13
97Stallion's Avatar
total agreement
I'm glad you agree Corey!!
But 98GreenStallion, as you can see Corey and I are in total agreement with each other and I would have to say we're probably the two most experienced people on the site. So just do what we say or it's off with your head.
Old 09-16-2004, 08:59 PM   #14
OrangeV6F150's Avatar
Good to hear yours are almost done I sent my heads and a cam in to Mik and he is working his magic with them.He already did my upper and lower intakes.Still waiting on the heads/cam, the machine shop messed up my heads and he is waiting for the previous guy to send his cores back..this sucks.
I have an extra set of 19lbs injectors from a 4.2l if your interested?
OrangeV6F150 is offline   Reply With Quote
Update to the update!!!!! Zebs5408 Pre-2005 V6 Mustang 19 01-29-2010 09:55 PM
Update SaturnMan8227 Pre-2005 V6 Mustang 2 03-20-2009 11:58 AM
Update silverstangboy 1979-1995 Mustang GT 14 12-27-2006 07:36 PM
Zim - update Monkey The Bar 7 05-22-2005 08:58 PM
S-10 update Smokedawg The Bar 8 03-07-2004 08:08 PM
12:52 AM
