Clean Your Engine - Mustang Evolution
Old 09-08-2004, 02:26 PM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Clean Your Engine
I live in the country roads and there's lots of dust flying around a lot of the time. Got a 2004 3.9 automatic that looks like its 99 cuz its so dirty. I don't know how to clean it. I tried some engine degreaser although it doesn't have grease just dirt and didn't work. I don't need some powerful formula I need some high pressure spray can that'll knock the dirt off. I've thought of spraying it w/ high pressure water at those do it yourself car washes but I'm afraid of ruining my engine. I don't know if I can do this cuz of the electrical thinngs in it. My friends tell me I only need to cover two things w/ plactic bags, near the spark plug wires and some other big piece. Any suggestions. Intake manifold is a pain, its rough texture won't allow you to scrub it...high pressure is manditory i think.
megax29 is offline   Reply With Quote
Old 09-08-2004, 02:42 PM   #2
just use a solution of simple green degreaser and water
Old 09-08-2004, 06:47 PM   #3
Fishers Stang's Avatar
use air? try that, then I would wake up one morning and just hose it down with a hose, make sure not to soak your engine.. we power washed all the engines at my old work, but i dont like doing it. make sure if your engine is Hot or warm, use HOT water...
Charles
Old 09-08-2004, 06:54 PM   #4
Send a message via AIM to Matt@StangMods
I used Purple Power and a small brush. It takes forever to do your entire engine but the results are great. Some people spray down their entire engine bay with Simple Green, then let it penetrate for a couple of minutes, and then finally hose the entire engine off. I have been too reluctant to try this because I do not want to ruin anything. Anyone else try this?
Matt@StangMods is offline   Reply With Quote
Old 09-08-2004, 06:56 PM   #5
timpryor's Avatar
i just use baby wipes to clean, and then megiures NTX to make everything look "wet"
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 09-08-2004, 06:58 PM   #6
we used kinda the same stuff, spray bottom up then let sit then brush heavy spots, then powerwash off, I live in Indiana and the dust from fields and normal grease and Oil, and mine is still clean,.... btw i have a 98/
Charles
Old 09-08-2004, 08:49 PM   #7
leo95's Avatar
What ever you do, don't use a high pressure washer, that's a short waiting to happen. Like Fishers Stang said, use air and blow majorty of the loose dirt out and then rinse it in the morning. When you do rinse the motor, be sure to leave it running, just to be on the safe side for your wires and connections.
95 GT :buckteeth
http://www.mustangmods.com/data/17461/mustang_056.jpg
Member #3 of the ME.com 5.0 Club
leo95 is offline   Reply With Quote
Old 09-08-2004, 09:16 PM   #8
fast64's Avatar
if you take a hose,pressure washer, etc to it, make sure the engine is running when you do it
GO BRAVES
Old 09-09-2004, 11:11 AM   #9
megax29's Avatar
You say to rinse it with water but do you mean i should just spray my entire engine up with my garden hose? Aren't I suppose to cover some **** up? I don't need a magic formula. I need to hose it down. When I spray something it breaks the dirt up sure, but I need something to make the dirt drip off of my engine. The solutions don't drip cuz there isn't enough of it.
Old 09-15-2004, 10:26 AM   #10
megax29's Avatar
I took it to a do it yourself car wash, covered up the ignition wires w/ a plastic bag and let it rip. Looks a lot better than before but not quite new.
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
Old 09-15-2004, 06:20 PM   #11
MonteCitan's Avatar
my 98 monte carlo.. with 80k miles on it in an also dusty/messy environment (lots of rain/mud puddles..) (previous car) simple green + toothbrush for hard to reach areas + hose, try to avoid the alternator and PCM housing, and don't spray water directly into the spark plug ports.. I just let the water run without any nozzles/etc.. it worked good as you can see..
I've also tried steam cleaning the visible parts without any connectors/gaskets nearby with a steam cleaner.. worked great, didn't cause any problems.. valve covers/parts of the intake plenum/ heads/exhaust/strut towers/etc
Old 09-15-2004, 06:54 PM   #12
my car the day be4 i put my strobes in.. 100,000+ miles on it.
Charles
started to clean up the engine bay (hiding wires 101) fast64 Pictures and Videos 4 01-07-2005 01:51 PM
How can I clean my engine? Ibanezplayer272 Mustang Audio & Video 6 10-24-2004 09:32 PM
How do you clean your engine...... Joseph1979 Pre-2005 V6 Mustang 13 07-12-2004 05:13 PM
Clean/Dressed Up Engine Bay? Dom Pre-2005 V6 Mustang 39 02-06-2004 08:26 AM
09:27 PM
