2008 3rd gear grind when cold - Mustang Evolution
Old 02-01-2009, 07:38 AM   #1
hi, my wife has a 2008 mustang 5spd and after it sits overnight and the temp is under 40 when she takes off first thing , third gear grinds when shifting. almost like the clutch is not pressed in. after it warms up, its OK. anyone else have this problem, thanks for anyone's suggestions.
the car is scheduled to go to the shop at the end of the month but i hate the thought of the trans coming apart. i thought about changing the fluid but i think it is already synthetic.
gotmach is offline   Reply With Quote
Old 02-01-2009, 09:08 AM   #2
Re: 2008 3rd gear grind when cold
one of two things probably (well it can be others but most likely one of these) the clutch does not have enough adjustment so it doesnt go in far enough, when warm its not as big of a deal. I am not sure this is it since the new mustangs have hydrolic clutches~ but its worth a check.
The syncro for 3rd is having some issues and cold weather makes it worse.
I know on my 03 cobra when its cold the transmission is notchy and if I tried to shove the shifter in gear fast it would probably grind on me~ when its cold always shift smoother and slower, ease it up to the shift gate and let it go in on its own.
You can change the transmission fluid and look for metal shavings if you want, at the end of the day its an 08 so it has a warranty, if you can make this happen every day then let ford check it out, generally they are worthless when it comes to diagnosing such issues but you never know.
Old 02-01-2009, 11:26 AM   #3
Scut95's Avatar
I have this same problem but with second gear. I do what spector said and just shift easy and slower when its cold and have no issues. I would check the fluid just incase but you should be fine, especially in an 08.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 02-01-2009, 04:18 PM   #4
Racin02GT's Avatar
Send a message via AIM to Racin02GT
its not internal in the trans ... ford issued a TSB for noise coming from the block plate between the engine and trans
Racin02GT is offline   Reply With Quote
Old 02-01-2009, 07:16 PM   #5
1234's Avatar
^^Then it would happen every shift not just in third.
Old 02-02-2009, 08:05 PM   #6
Racin02GT's Avatar
my bad... i was thinkin of another one... we've had a few cars in the shop with that complaint and that fixed it but they just released a new TSB last week
FORD:
2007-2008 Mustang
ISSUE:
Some 2007-2008 Mustang vehicles equipped with the 4.6L engine and TR3650 5 speed manual transmission may exhibit a clash noise and / or raspy (rough) feel on gear engagements during 1-2 or 2-3 upshifts. This condition may be more pronounced when the transmission is colder than 40 degrees F (5 degrees C).
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Remove the transmission following Workshop Manual (WSW), Section 308-03B.
2. Replace with new the 1-2 sychronizer and 3-4 sycronizer assemblies, following WSM, Section 308-03B.
3. Install the transmission following WSW, Section 308-03B.
PART NUMBER PART NAME
3R3Z-7124-BA 1-2 Synchronizer
1R3Z-7124-DA 3-4 Sychronizer
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION
080906A
DESCRIPTION
2007-2008 Mustang 4.6L Engine TR3650 Transmission: Replace The 1-2 And 3-4 Synchronizers, Includes Time To Remove And Install Transmission (Do Not Use With 7003A, 7003A2, 7003AZJ, 4602A, 5212B, 7564B)
TIME
6.6 Hrs.
Old 02-02-2009, 08:14 PM   #7
Scut95's Avatar
Wow, I think all Tremic trannys do this and they are actually trying to fix it now!? It sucks that you only get 6.6 hrs to R&R and rebuild half the tranny. Good old warranty work
95 GT- Sold
Old 02-04-2009, 11:02 PM   #8
Joe_SHO's Avatar
Region: North Dakota
Rev second high then hit up fourth.
Joe_SHO is offline   Reply With Quote
Old 02-04-2009, 11:11 PM   #9
^haha, i do that now cuz my thrid gear is shot lol.
96 GT- Who knows what's in it.
Old 02-05-2009, 07:22 AM   #10
1234's Avatar
^^ I did that as well for a while . Then I snapped something and 4th no longer worked either.
Old 02-05-2009, 07:41 AM   #11
^^ that effin sucks lol. hopefully i get my new tranny when the irs pays me. been shifting like that for a while now, its so bad i drive the daily driver the same way lol.
Old 02-05-2009, 08:36 AM   #12
1234's Avatar
Yeah i started doing the same thing. Where you getting your tranny from?
Old 02-05-2009, 10:49 AM   #13
MonteCitan's Avatar
Do the V6s use Tr3650s like the GTs now? or still the T45s?
The tremecs in 2004+ are supposedly a lot better, I know my 02 had 1-2 and 2-3 cold temp grinding issues, but I fixed that as per the TSB
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-05-2009, 04:57 PM   #14
i dunno, i guess when i get my check ill look around. would like to find a bad *** deal but u know how that goes, when u are broke they are everywhere and when u have money there isnt any lol. did u upgrade yours yet?
Old 02-05-2009, 04:58 PM   #15
i wanna say they were still using the t-5/t-45's.
Old 02-06-2009, 06:47 AM   #16
1234's Avatar
Yeah i already upgraded mine with a stock replacement that has the fixed internals. Check out Rebuilt Transmission | Manual Transmissions | Mustang | Truck. Thats who i got mine from. They took care of me for under $1000. With 6 month unlimited mileage warranty.
Old 02-06-2009, 07:07 AM   #17
v6's from 94-04 used the T-5 and in 05 I am not sure what they went to
Grinding into 3rd gear tedness 1996-2004 Mustang GT 9 01-19-2010 06:32 AM
reverse gear grind chris098 1996-2004 Mustang GT 8 01-21-2008 09:49 PM
clutch grind ChickStang02 1996-2004 Mustang GT 21 03-24-2007 05:20 AM
transmission stuck in 3rd gear need help theglory 1979-1995 Mustang GT 18 02-15-2006 10:20 AM
How hard to grind off powdercoating on MM sub frames? SpectorV Pre-2005 V6 Mustang 3 05-19-2005 05:20 PM
08:26 PM
