You guys with idle issues (possible vacume leak) try this - Mustang Evolution
Old 09-18-2004, 05:00 PM   #1
If you think you have a vacume leak crank the car if the car wont idle normally crank it and pump the brake, if the car idles fine then its a vacume leak.
Old 09-18-2004, 08:53 PM   #2
Mine will just idle really low every once in a while..dunno what the issue is
Old 09-18-2004, 08:57 PM   #3
fast64's Avatar
i could tell mine was a vacuum leak b/c a bunch of caps were missing, lol
GO BRAVES
Old 06-01-2010, 01:28 PM   #4
Mercedez L.'s Avatar
Re: You guys with idle issues (possible vacume leak) try this
Mine was the engine intake manifold gasket causing the problem (leak).
But only after replacing the ACT, ECT sensors, IAC Valve & gasket and cleaning throttle body.
Mercedez L. is offline   Reply With Quote
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 09:08 AM
Hot start idle issues Scorpion1 Pre-2005 V6 Mustang 12 04-07-2009 04:58 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
how much vacume at idle initialb 1996-2004 Mustang GT 2 08-03-2006 10:54 AM
3F3Furious leak Thomas91169 The Bar 22 11-09-2005 07:53 AM
07:36 PM
