eatons blower - Mustang Evolution
Old 09-18-2004, 06:08 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
eatons blower
i just wanted to know is the roots blower off a moderen GTP a m-90? b/c i think they have a better flow then a the old t-birds. thanks for the help
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 09-18-2004, 06:11 PM   #2
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
try a grand prix forum they would no more, if you want it on a stang i think itd be more of a hassle than its worth, sorry that i couldnt help much..
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 09-18-2004, 07:40 PM   #3
Fishers Stang's Avatar
wont work, i talked to lots of techs at my old job, and they said your car would be down for a long time tryin to fit it on there, and then to mix all the extra stuff you need. 3800's are not the same as a 3.8. diffrent intake, and some internals. just fyi.
Charles
Old 09-19-2004, 02:48 PM   #4
no no with this new roots system thats someday coming out, its doesnt matter weather its a GM or Ford as long as its an M-90 they can make it work for free.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 09-20-2004, 08:25 AM   #5
it wont bolt up to your car and even if it did the bottom end cant take alot of boost so... you will have to keep the boost turned down which will make you make less hp, but you will still make good tq due to the roots blower...however a centrifugal SC (procharger) will let you run more boost, higher up rpm peak boost, make more hp and less tq than the roots (still same tq numbers or close to it just takes more psi to do it, basically it would be well worth it if the bottom end could take alot of punishment, and it may can just be leary.... and its alot of headaches to set up.
Blower options.. MonteCitan 1979-1995 Mustang GT 9 01-24-2009 08:24 AM
New Whipple Blower JROC 1996-2004 Mustang GT 34 09-26-2007 02:07 PM
yet another blower update whipster24 The Bar 4 11-09-2004 09:28 PM
The Roots Blower Dom Pre-2005 V6 Mustang 9 09-24-2004 12:27 PM
roots blower charkelly9 Pre-2005 V6 Mustang 3 08-25-2004 09:36 PM
05:31 PM
