drag racing with an auto - Mustang Evolution
Old 09-21-2004, 10:42 AM   #1
Is it better to have the car in drive and just floor it, or is it better to manually shift form first to second to third to fourth
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 09-21-2004, 10:44 AM   #2
I liek gramer
WhiteStang99's Avatar
i think we had a long debate about this once. I know Laser02 was involved... Search around.
Old 09-21-2004, 10:47 AM   #3
Drive and floor it. The computer can shift faster than you can
Old 09-21-2004, 11:09 AM   #4
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
I just leave it in Drive.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 09-21-2004, 11:55 AM   #5
It responds better if you just leave it in drive..but I still love popping it from drive to second to chirp the tires between gears
Old 09-21-2004, 01:52 PM   #6
Bane-'s Avatar
wouldnt taking it from drive to 2nd end up hurting the tranny in the long run since your foot is still on the gas?
Old 09-21-2004, 02:04 PM   #7
I let off the gas, but yes, i'm sure it's screwing up my tranny doing that.
Old 09-21-2004, 04:15 PM   #8
Monkey's Avatar
leave it in drive. the only reason to put it in 2 or 1 is if you're towing something or going up or down a steep grade.
whatever you do. do NOT put it in neutral and then pop it in drive. neutral drops will drop your tranny.
Old 09-22-2004, 07:46 PM   #9
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Tell you the best way to shift your automatic car.... Swap it out for a manual! lol
Just let the computer do it... but take off the overdrive!
Rellik is offline   Reply With Quote
Old 09-22-2004, 08:45 PM   #10
I did that whole neutral drop thing in my old car...it didn't last very long...
Old 09-22-2004, 09:35 PM   #11
Monkey's Avatar
overdrive doesnt matter. it's not like if you take it off, the first 3 gears change length. and you sure don't want to be in 3rd gear at 90mph.
Old 09-22-2004, 10:30 PM   #12
They'll do 105 in 3rd...lol
Old 09-23-2004, 10:47 AM   #13
a higher mph in a given gear is not something to be braging about if you are talking about acceleration.
Old 09-23-2004, 11:00 AM   #14
Zim
You want to **** me?
Zim's Avatar
my 1/4 mile passes never went into fourth gear... ran 91 mph both times with my 4.10s on the juice
I like toys
Old 09-23-2004, 11:13 AM   #15
Monkey's Avatar
its okay while dragging at the track, but if you go over 90mph then i would put it in 4th. you dont want to turn off OD on a highway race. you'll wear out 3rd gear.
Old 09-23-2004, 12:43 PM   #16
Yeh, it was on a highway race...I don't do it very often..don't go over 80 very often, trying to keep my car in one piece. I go easy on her most of the time
Old 09-24-2004, 07:52 PM   #17
i love racing with my auto, since the gears and sct tune it will chirp without changing it manually. As a matter of fact when i do try to change it myself it feels like to much wear on the trans
99 mustang gt auto vert
mac cold air
mac prochamber
mac cat back
c & l plenum, mac 70 mm throttle body
4.10 gears reinhart sct tuner
17 x 9 bullit chrome rims
vortech v-1, 42 lb injectors,lightning 90mm maf anderson power pipe,
before vortech dynoed 230.8 rwhp, 268.0 rwtp
with vortech 350 rwhp, 340 rwtp
greg_g70 is offline   Reply With Quote
Old 11-05-2004, 06:41 PM   #18
when the computer shifts it shifts at 5500 red line i manualy shift my about at 6200 rpm (moved the rev limiter up a bit). the benifit is more hp developed out of that gear by keeping in the power ban longer. With my supercharger that etra few rpms has a dramatic effect on boost. i can computer shift and get 11 lbs boost...manual shift and get 14 lbs. also on a aode trans 4th gear or overdrive is a varation of the torque converter not being locked up all the way. its not really a gear. Auto use clutch in a drum pack. 1st gear ...2nd ....3rd.... then od then lock up in final drive. its like having 5 gears. i race with od off and hit 100.53 mph @ 13.7 and my trans is fine. This is my work car too. shift it and have some fun.
drive it like you stole it
smokin6 is offline   Reply With Quote
Old 11-13-2004, 10:35 AM   #19
Kiljosh's Avatar
I usually only push the brakes in then give it gas till right before tires spin, hold it there, wait for 3rd light and floor it. Start in drive everytime then I shift down to second then back up to drive and let compy handle the rest....
Old 11-15-2004, 05:43 PM   #20
slvr2000stang's Avatar
I leave it in D since mine shifts hard & fast with the current tune.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Drag racing Js281GT ME Site Help & Announcements 6 04-17-2006 06:28 AM
Drag racing will kill you... Fishers Stang The Bar 22 05-30-2005 10:36 AM
Cams and drag racing... Exit_In_Red Pre-2005 V6 Mustang 7 02-07-2005 03:51 PM
no drag racing oaktonarcher The Bar 18 10-03-2004 09:19 AM
Alittle ricer drag racing/street racing show on History channel video Brent The Bar 15 05-06-2004 11:26 PM
01:02 AM
