torque - Mustang Evolution
Old 02-06-2009, 12:13 PM   #1
torque
Does anybody know what to torque the spark plugs at?
I also have a cracked Drivers side manifold i do plan on replacing this when spring comes around. Does anyone have suggestions.. I have heard that the studs sometime snap. what's the torque on that i forget offhand..
2001 Stang V6
Werewolfmage is offline   Reply With Quote
Old 02-06-2009, 12:21 PM   #2
re: torque
torque , just snug is fine, prolly 25-30 ft/lbs not tight at all on aluminum heads, the aluminum will swell and they will be a pita to take back out.
SimplyOrange is offline   Reply With Quote
Old 02-06-2009, 12:22 PM   #3
re: torque
Ty
Old 02-06-2009, 12:32 PM   #4
re: torque
17ish ft pounds is usually the number recommended. Basically, go till they feel tight with the ratchet, then go 1/8-1/4 turn.
Old 02-06-2009, 12:55 PM   #5
Herbstang's Avatar
re: torque
3.8L Torque Specs
Camshft sprocket bolt 30-36 ft/lbs
Camshaft thrust plate bolts 72-120 in/lbs
Crankshaft pulley to vibration damper bolts 20-28 ft/lbs
Cylinder head bolts
-1994 to 1995
--Step 1 15 ft/lbs
--Step 2 29 ft/lbs
--Step 3 37 ft/lbs
--Step 4 Loosen 2 full turns (from this point on, work with one bolt at a time)
--Step 5 (Long bolts) 11-19 ft/lbs
--Step 5 (Short bolts) 7-15 ft/lbs
--Step 6 Tighten additional 90 degrees
-1996-later
--Step 1 15 ft/lbs
--Step 2 29 ft/lbs
--Step 3 36 ft/lbs
--Step 5 (Long bolts) 29-37 ft/lbs
--Step 5 (Short bolts) 11-18 ft/lbs
--Step 6 Tighten additional 180 degrees
Exhaust manifold bolts 23-26 ft/lbs
Flywheel mounting bolts 54-64 ft/lbs
Intake manifold to cylinder head bolts
Oil pan mounting bolts 84-108 in/lbs
Oil pump and filter body to front cover
8mm bolt 17-23 ft/lbs
6mm bolt 72-96 in/lbs
Rocker arm fulcrum bolts
-1994 to 1995
--Step 1 44 in/lbs
--Step 2 19-25 ft/lbs
-1996-later
--Step 1 44 in/lbs
--Step 2 22-29 ft/lbs
-1994 to 1995
--Step 1 96 in/lbs
--Step 2 15 ft/lbs
-1996-later
--Step 1 72 in/lbs
--Step 2 108 in/lbs
Spark plugs 7-14 ft/lbs
Timing chain cover to block bolts 15-22 ft/lbs
Valve cover bolts 72-108 in/lbs
Vibration damper bolt 103-132 ft/lbs
Water pump to timing chain cover bolts 15-22 ft/lbs
Wheel lug nuts 85-105 ft/lbs
Old 02-06-2009, 01:12 PM   #6
re: torque
i never torque them, i just know how tight.
Old 02-06-2009, 01:13 PM   #7
Herbstang's Avatar
re: torque
Thats cause your the man
Old 02-06-2009, 01:17 PM   #8
re: torque
yep and you are the human search engine
Old 02-06-2009, 01:38 PM   #9
re: torque
LOL i just realized i spelled torque wrong Oh well.. TY for all the replies!
Old 02-06-2009, 11:09 PM   #10
re: torque
oh.. I forgot to ask...What is the gap on the plugs for the v6. what plug would you recommend? i was thinking Autolites or Ngk's.
Old 02-06-2009, 11:33 PM   #11
DaDant!'s Avatar
re: torque
Answer
I just changed mine and the sticker on the hood says .052 to .056 and the guy at the parts store said shoot for .054
.054
edit: and i would go NGK
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Old 02-07-2009, 01:12 AM   #12
re: torque
Sweet thank you
Old 02-07-2009, 07:40 AM   #13
re: torque
No...do not go NGK. The best plug for a V6 will be the autolite. You are wasting money with anything else.
Old 02-07-2009, 12:27 PM   #14
DaDant!'s Avatar
re: torque
he knows better than me.
im getting there.
Old 02-07-2009, 12:31 PM   #15
Send a message via AIM to VCS_SSSTANG
re: torque
NGK is all I run in my car... N/A - supercharged - turbo - whatever NGK
VCS_SSSTANG is offline   Reply With Quote
Old 02-07-2009, 12:35 PM   #16
hottcobra's Avatar
Re: torque
fixed it for you
Old 02-07-2009, 12:52 PM   #17
DaDant!'s Avatar
Re: torque
just so you know that is the gapping for 01 v6 i searched for it and that is the answer i found. hopefully i didnt confuse you because i have a gt.
im getting there.
Old 02-08-2009, 04:10 AM   #18
Re: torque
well I bought autolite plats. The stang had motorcraft plats in it. They were really whooped. could possibly be original stuff that came with the car. the gaps were so wide i could stick a half dollar in it. Ty for all the feedback
Old 02-09-2009, 07:42 AM   #19
Herbstang's Avatar
Re: torque
Hell Ya !!! I gotta do something with my time at work
More Torque Bullitt03 Pre-2005 V6 Mustang 12 12-17-2007 06:26 PM
Got Torque? PureVenom Pictures and Videos 5 10-06-2006 02:50 PM
Need a torque spec?? Rick0636 Pre-2005 V6 Mustang 12 06-01-2006 02:45 PM
Torque converter DarkShadow Pre-2005 V6 Mustang 5 05-07-2006 07:36 AM
torque converter tealstangman 1996-2004 Mustang GT 4 04-06-2006 05:51 PM
02:12 PM
