Doesn't idle down. - Mustang Evolution
Old 02-07-2009, 01:16 PM   #1
Joe_SHO's Avatar
Region: North Dakota
Doesn't idle down.
I have a stock '02. When you're driving and push in the clutch, it takes what seems like too long before the engine returns to idle speed. A friend of mine thought they might have put a heavier flywheel in the V6's to compensate for less power? Any intel appreciated.
Joe_SHO is offline   Reply With Quote
Old 02-07-2009, 04:30 PM   #2
hottcobra's Avatar
Re: Doesn't idle down.
that is normal. the ECM reads the car's speed and holds the idle up for a while. It will do it if you have an auto and shift into nuteral aslo
Old 02-07-2009, 06:21 PM   #3
Joe_SHO's Avatar
Is there anyway to alter that? It's the only manual tranny i've ever driven that does it, so naturally it feels wrong. It also makes it hard to engine brake.
Old 02-07-2009, 06:25 PM   #4
1234's Avatar
You can get a hand held tuner and change the rpm decay rate of the motor. Or put a lighter flywheel on it.
Old 02-08-2009, 08:46 AM   #5
my 01 v6 did the SAME thing. A tuner and modify the idle decay rate and fix your issue
Old 02-08-2009, 01:59 PM   #6
Joe_SHO's Avatar
Aight thanks for the help guys. I appreciate it.
Old 02-09-2009, 07:59 AM   #7
Herbstang's Avatar
Had the same issue Once I got A SCT Chip they decrease the dashpots and idle decay rate and solved the problem Ford will say it's normal due to emission control to burn off excess fuel that it is controlled by the computer and they can't do a thing about it
Old 02-12-2009, 07:44 AM   #8
SC_STEEDA's Avatar
i was just about to start a thread about this b/c i have had my a manual mustang for 5 years now and its just now starting to do it.
2003 LAND ROVER DISCOVERY-These are amazing off-road vehicles to be stock!
2001 3.8L TOTALED
CAI; HELI-X Throttle Body Spacer; MOTOBLUE Pulley Kit 42%; Crank 5% Water; Harmonic Balancer; WIRES; EIBACH Sport Springs; FLOWMASTER Dual 40 Series turndowns!
"You want something. Go get it. Period. Don't ever let someone tell you... you can't do something."
SC_STEEDA is offline   Reply With Quote
Idle Problem Help!! W225110 1979-1995 Mustang GT 7 03-30-2010 07:12 PM
ruff idle noslow5ohh 1979-1995 Mustang GT 11 07-02-2008 09:01 PM
Unsteady Idle Ibanezplayer272 1979-1995 Mustang GT 21 06-04-2008 06:33 PM
how much vacume at idle initialb 1996-2004 Mustang GT 2 08-03-2006 10:54 AM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
12:07 AM
