Well I did it - Mustang Evolution
Old 09-26-2004, 07:36 PM   #1
Well I did it
14.985 @ 91.19
still hitting 2.2 60's so that sucks....I need 4.10s
but I ran that and 14.992 and 15.004....
this was full street trim with the 17s on, crap in trunk, spare, etc. etc...
I'm going wed with my 16" DR's and no crap/spare to see how low I can drop it.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 09-26-2004, 07:45 PM   #2
Monkey's Avatar
looks good. Don't know if you have auto or manual, but if you have an auto, get a torque converter and lower your 60's to 1.9-2.0 and shave .5 off your ET.
Old 09-26-2004, 07:53 PM   #3
timpryor's Avatar
auto
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 09-26-2004, 08:07 PM   #4
I have a converter...it wont drop below 2.2 60's...
I have 3.73s and my motor isnt setup for low-end grunt. I'm gettin 4.10s eventually to try and get it down to a 2.0
New Hottness
1999 V6 5-speed
Wrecked
Old 09-26-2004, 08:42 PM   #5
Monkey's Avatar
that's odd because i was cutting 1.9s all day long w/ 4.10s a converter and other minor bolt-ons. Maybe try setting up your suspension different? I had lowering springs and softer rear shocks w/ stiff front struts and rear sway bar.
Old 09-26-2004, 08:44 PM   #6
im not spinning, just no low-end.
dont forget I have heads/cam. They make a lot more HP than they make tq, and shift everything way up in the rpm band. Its not a low-end setup and with the auto it just isnt THAT torquey.
I just need more gear.
New Hottness
1999 V6 5-speed
Wrecked
Old 09-26-2004, 08:48 PM   #7
Monkey's Avatar
what's your stall at? why not brake stall higher so you are closer to your power band?
Old 09-26-2004, 08:55 PM   #8
i brake stall to 2400 still dont od nothing. flash stall is 3k.
between heads/cam/LT's w/ 2.5" pipe my tq is shifted at or above 3k..
3.73 never were enough and with me adding more and more top-end i need more gear.
New Hottness
1999 V6 5-speed
Wrecked
Old 09-26-2004, 11:28 PM   #9
01mineralgrey6's Avatar
Good run, and good luck!!
-Tony
'99 cobra 'vert
Old 09-26-2004, 11:50 PM   #10
4.10s in a auto are required for V6 mustangs... I have 4.10s in my v6 and its still annoying slow ... i dont know how i made it with 2.73's and open diff
11:12 AM
