finished my rear end swap - Mustang Evolution
Old 07-19-2003, 11:20 PM   #1
Monkey's Avatar
after almost 2 weeks on jackstands, i finally was able to finish installing my car's new rear end. (i misused two lower control arm bolts and so i had to get a new set... THANKS goes to Suprman!!!)
anyway, i put the stock 7.5 back in w/ the open differential, and 2.73 gears. i swapped an 8.8 w/ 4.10s to someone on 3.8mustang.
the car feels kinda different. it may be my conveter still in there, that is making it seem faster than it should be. also, i cant tell if my speedo is correct (yes, i swapped out the speedogears while i was putting both rears in) and when i floor it, my whole car kinda jerks forward and to the left a bit. darn 1-wheel-drive. too much power going to that one wheel only and it feels as if when my shift kit kicks in, it moves the car to the left some
need a bit more driving on it to see if the speedo reading is accurate again or not, but hopefully it is.
Old 07-27-2003, 04:14 PM   #2
dapack69's Avatar
Send a message via Yahoo to dapack69
So how much slower is your car now?
dapack69 is offline   Reply With Quote
Old 07-27-2003, 04:46 PM   #3
Monkey's Avatar
actually not much. its weird cause the converter is taking over the lower end. i mean i can feel a difference, but it still shifts all with one wheel. so that takes some getting used to
Old 07-27-2003, 05:23 PM   #4
dapack69's Avatar
I need to get a converter bad. But my gears whine and I need to get that fixed first.
I have a bone stock steering wheel.
http://www.gotstang.com/profile.php?dapack69#jump
rear end swap 98mustang2007 Pre-2005 V6 Mustang 2 11-11-2007 06:21 PM
doing a rear end swap in the morning jimmy_beaner The Bar 7 05-20-2005 09:47 PM
Rear end swap Sublime782 Pre-2005 V6 Mustang 20 03-26-2005 07:13 PM
Mod 7.5 or Do An 8.8 Rear End Swap? Donny B Pre-2005 V6 Mustang 2 11-30-2003 04:15 PM
Rear End Swap Ken Pre-2005 V6 Mustang 13 10-02-2003 01:49 PM
06:18 PM
