Getting a V6 to run at least 14.2's - Mustang Evolution
Old 10-07-2004, 08:11 PM   #1
Send a message via AIM to StangGurl Send a message via MSN to StangGurl
Question Getting a V6 to run at least 14.2's
I have no idea how to modd a V6 to run into the 14's at least without sticking nitrous on it. I had a V8 and that was easy to mod, but V6 is a different story for me, where do I start!
StangGurl is offline   Reply With Quote
Old 10-07-2004, 08:15 PM   #2
4.2l stroker, and a supercharger on top of it all.
of course your tranny will prolly give out and so will the diff so you will have to mod those too
Old 10-07-2004, 08:20 PM   #3
timpryor's Avatar
talk to stang 99 he runs 14's in an auto NA 3.8
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 10-07-2004, 08:20 PM   #4
14.9's he runs. you should talk to rgr
Old 10-07-2004, 08:22 PM   #5
RGRCFM1@yahoo.com
thats rgr's email
Old 10-07-2004, 08:23 PM   #6
timpryor's Avatar
well if she did the same mods w/a stick she would be fairly close.
Old 10-07-2004, 08:35 PM   #7
good point wonder if she has a manual
Old 10-07-2004, 08:44 PM   #8
Danger Dude's Avatar
97Stallion (Rob) and my car are in the 14's there is currently about 3/10 difference between his 4.2 and my 3.8. He has BV heads and I have yet to install mine
Old 10-07-2004, 09:35 PM   #9
Zim
You want to **** me?
Zim's Avatar
corey an 11 second 1/8th mile isnt gonna put you in 14s for the quarter
I like toys
Old 10-07-2004, 09:38 PM   #10
I would recommend exhaust first, then move to directly to heads cam and intakes and 3.73 gears if you have a manual and 4.10 gears if you have a automatic
Old 10-07-2004, 09:41 PM   #11
Monkey's Avatar
spray it. a 100 shot with a cold air, duals and gears and you're there.
Old 10-08-2004, 08:09 AM   #12
What are you talking about I ran a 9.896 and never slower than a 10.0 and that was major wheel spin at launch
The only 11 I posted was the run I started in 2nd gear. I forgot to put it in Drive DOOOOHHHHH!!!!!
Old 10-08-2004, 12:22 PM   #13
a 9.8 is low 15s...I ran a 9.578 1/8 and ran 14.9....
And my car has a 14.5 in it...I ran 14.9 with a 2.2 60'. Get that down to 1.9-2.0 and I run 14.5
Gimme a 5spd and I run low 14s/high 13s.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 10-08-2004, 12:46 PM   #14
Well I would have had lower times but I was having a problem with wheel spin. I need some Drag Radial
The other thing is power band The cam I have seems to also like higher RPMs. The fact is if you continue to build Hp as you head down the 1/4 times can be different
Old 10-08-2004, 12:48 PM   #15
My cam pulls hard from 4-6k.
what were you're 60's like? With an N/A car you won't pull that that much harder in hihger rpm's to affect your times a lot. Thats more of a turbo/nitrous thing.
a 9.8 1/8 is like a 15.2
edit: also, what's your trap in the 1/8?
New Hottness
1999 V6 5-speed
Wrecked
Old 10-08-2004, 12:53 PM   #16
heads/cam/intake/4.2 strocker with a tune and bolts ons = mid or low 13s with a five speed with gears and slicks.
Old 10-08-2004, 01:10 PM   #17
9.894 1/8 73.817 mph 2.219 60's reaction time .223
Like I said I was having severe wheel spin at launch. really poor track conditions were also a problem
Old 10-08-2004, 01:31 PM   #18
you got alot more in it, i was doing those numbers with 2.2 60fts with my 01 and bolt ons and gears of course.
Old 10-08-2004, 01:45 PM   #19
Yes I agree. And when I get my RPM BV heads on I will be making another 20+ HP. My launches need to improve, Drag Radials and some more pratice will also improve my times. hell the stock 99+ were running 11's. Only once did I see one break into the high 10's
Old 10-08-2004, 10:28 PM   #20
Thanks guys for all your replys... sorry I havent gotten back sooner to reply.. I have an Automatic and she is a daily driver, if that makes a difference on how I approach modding her
Old 10-08-2004, 11:42 PM   #21
is the 7.5 dif that weak ?? can i do a 4.10 with my stock 7.5 dif . and another thing is it posible to make it posy with out buying a posy unit ? i dunno shims?
InVaDeR is offline   Reply With Quote
Old 10-09-2004, 12:09 AM   #22
Monkey's Avatar
no, you have to buy a posi unit. you can make a locking differential by welding the spider gears but that is a track only setup as you will wear your tires a lot and squeel them during turns.
yes, you can do 4.10s with the 7.5 rear.
Old 10-09-2004, 07:44 AM   #23
Zim
Zim's Avatar
thats what i was referring to, just givin you a hard time old pal
I like toys
Old 10-10-2004, 01:46 AM   #24
97Stallion's Avatar
Stang gurl, if you want to "mock" my setup, you'll be able to get into the low 14's Like Corey said, the track conditions were pretty crappy at the last meet, so we weren't able to really hook on the launch. But I know I can into the 14's atleast with my setup if not upper 13's.
Living one day at a time!
Old 10-10-2004, 06:18 AM   #25
97Stallion- Okay, kool. I think I might do somethings to it over the wintertime when its just sitting doing nothing.
Old 10-10-2004, 08:34 AM   #26
I still don't see how you guys think you'd run low 14s...
running 7.6 and trapping at 73 in the 1/8 is like a 15.0-15.2 1/4... your not turbo/nitrous so your car isnt going to pull THAT much harder past the 1/8.
my car wont cut less than a 2.2 60' as is. Thats with it dead hooking with my DR's. The engine just doesnt have enough lowend with the ****ty automatic gearing and 3.73s.
4.10s are next to get me to 2.0 or less.
New Hottness
1999 V6 5-speed
Wrecked
Old 10-10-2004, 10:25 AM   #27
Monkey's Avatar
with 4.10s and converter, i was cutting 1.9 60's all day long. even on street tires. I also had slicks for when i would spray off the line.
bottom line stanggurl - the cheapest way would be nitrous, 4.10s and t-lock, dual exhaust and cold air intake
Old 10-10-2004, 12:06 PM   #28
that's what I cant wait for. The car just wont cut less than a 2.2
A 2.0 or 1.9 puts me mid-low 14s as the car sits. And I plan on new heads/cam/intakes for spring too so who knows.
New Hottness
1999 V6 5-speed
Wrecked
Old 10-10-2004, 11:18 PM   #29
97Stallion's Avatar
If you need some help, just ask your questions here and I'll help you as much as possible.
Old 10-10-2004, 11:20 PM   #30
97Stallion's Avatar
Actually a 9.6 is high 14's. It's like a 14.7-14.9. Anyways, that was on a slick and dirty track and also I wasn't in my groove shifting and all. Shifting plays a big part in your track times. I'm suppose to go to Darlington this weekend, so I'll post my 1/4 times if I go.
Old 10-11-2004, 12:31 PM   #31
New Hottness
1999 V6 5-speed
Wrecked
Old 10-13-2004, 03:23 PM   #32
I ran 71.09 mph in the 8th, sat night. K&n filter is my only mod. hmmmm
oh1coupe is offline   Reply With Quote
Old 10-13-2004, 03:38 PM   #33
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
ok im new to drag racing, but why is you MPH much higher then the person you ran aginst and he still ran a sec faster then you? doesnt that mean that your car should have alot left in it? could you be able to run a 13ish time?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 10-13-2004, 04:58 PM   #34
That means the other guy let off the gas early
Old 10-13-2004, 08:11 PM   #35
but how could u run in the 13s and be at 81 mph? i mean that sounds so slow. and dont you think at 91 mph the car has better times in it?
Delta Sigma Phi
www.DeltaArmsCo.com
It won't run upton7 1996-2004 Mustang GT 5 05-21-2009 08:55 PM
what should i run? 07stang General Mustang Discussion 26 03-11-2009 07:50 PM
Had a run-in with a GT... MarkuzLS1 The Bar 15 03-01-2007 09:01 PM
Had a run it with a '02 GT Scoot99V6Stang The Bar 33 12-11-2005 03:24 AM
Trying to run 14.5 cms09071987 Pre-2005 V6 Mustang 12 08-25-2005 04:56 PM
03:47 AM
