What is the most aggressive gear I can go with? - Mustang Evolution
Old 07-21-2003, 12:04 AM   #1
Send a message via AIM to ASSEMbler
What is themost aggressive gear I can use in a standard v6 rear (2000)
I am a while from needing a 8.8.
ASSEMbler is offline   Reply With Quote
Old 07-21-2003, 12:12 AM   #2
Zim
You want to **** me?
Zim's Avatar
4.10 probably... 5 speed people usually go with 3.73's though so they actually have a first gear. In my auto im outta first gear by 25, i couldnt imagine how quick itd go in a 5 speed.
I like toys
Old 07-21-2003, 04:00 AM   #3
tire's Avatar
Send a message via AIM to tire
if you know now you want an 8.8 someday, don't waste a dime with the 7.5.
i got new gears installed on an almost new rear end, plus cost of rear end all for 575$.
for tlok and gears installed it will be about 450$ or more.
pretty easy math isn't it!
i have 4.10s in my 00 5spd and i wouldn't go any higher. if i'm speeding (say 47mph) in a 40 mph zone, i get into 5th gear if that tells you anything!
-austin
tire is offline   Reply With Quote
Old 07-21-2003, 09:27 AM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I've seen gear ratios up in the 5's somewhere. I'll look for a link...
Rellik is offline   Reply With Quote
Old 07-21-2003, 09:42 AM   #5
Aggessive
Well my reason is the faster I launch the faster I can hit the nitrous, or build to boost, etc. Top end.. well face it, in street race by me top limit is usually about 120. Most rice can't fry faster than that by me.
Old 07-21-2003, 09:48 AM   #6
If you are going to spray and have boost Def. Dont bother with a 7.5 cause it wont last long.
Old 07-21-2003, 01:05 PM   #7
tire's Avatar
Re: Aggessive
you won't be about to go past 100mph with 4.10s while redlining even...
learn more, then act. good luck!
Old 07-21-2003, 01:38 PM   #8
The lower gear ratio you go, the more your top end will suffer (not to mention your gas milage).
Old 07-21-2003, 01:45 PM   #9
100 with 4.10
I can't go past 100 if I use 4.10?
I take the car to 110+ every day.
Old 07-21-2003, 02:07 PM   #10
Monkey's Avatar
the highest i have ever seen for the 7.5 rear is 4.56s. those have to be custom made too and are pretty expensive. for the 8.8, they actually make them in the 6's
why do you go that high? kills your mpg, too fast, endangering lives (including yours), tickets, etc. just not worth it. be smart, drive smart.
with 4.10s you can go 100+ you just need a chip to recal the speedo and since youre a 2000, it will fix the speedo and youll be really close to redlining. take your rpm's at any specific speed, and add about 500 to it. thats what 4.10s will do to upping your rpms. so if at 110mph, youre at 3100 and your redline is 3600, then you would be at redline doing 110mph w/ 4.10s
Old 07-21-2003, 03:13 PM   #11
Danger Dude's Avatar
Re: 100 with 4.10
well then you have a chip with a 2000 If not you are like 15 or more MPH off so you are not going 110
Old 07-21-2003, 06:00 PM   #12
Ken
Ken's Avatar
Region: New Hampshire
I would NEVER recommend replacing the gears on the 7.5" rear end. I did, and for the same damn money I could have had the same damn gears with the T-lok in an 8.8!
Here is the saying I've been living by... "There's never enough money to do it right the first time, but always enough money to do it again!"
Don't make the same mistakes I made.
Don't install gears in your 7.5
Don't get Shorty Headers
Don't spend over $100 on a CAI
Don't Buy GT Wheels when good deals come across on the Steeda UltraLights!
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 07-21-2003, 06:29 PM   #13
I dont 100 % buy the dont put gears in a 7.5 I would say that if you are a track rat and are going to use slicks and you are pushing 300 hp. But at the same time you come across a good deal on 8.8 hell go for it.
Dont get shorty header unless you want to keep near stock and you have a 99+ with crappy exhaust headers. Us lucky enough to have 97-97 have nice headers and unless you are one again going over 300 dont bother changing them
CAI are nice I like them but as to there claims of HP by themselves I think a nominal gain is there just dont think it is as some claim 10 to 15 HP unless you have a larger T/B and stage 3 intakes and heads
Corey
Old 07-22-2003, 10:14 PM   #14
Speed
Yes, I peg the needle almost every day. On open road, with no one on it. This are highway stretches with no shoulder on either side ( I know, insta-death in a wreck) and there are no cops.
Any idea what an 8.8 and a Tloc 4.10 would cost? So I know what to look for. And yes, stage 3 is on the way and will go on top of a complete rebuild. I got the block off a local wrecker for $200 as it has no ECU.
110 redline on 4.10 would be a problem. I mean, I don't own the mustang to go slow.. If I go with a lower gearing, what can i do to get off the line faster?
Old 07-23-2003, 05:29 AM   #15
There are safe time on the interstate where you can drive WOT. That is where I speed most often. It is wide open and the pavement is in good condition usually.
Corey
Old 07-23-2003, 11:20 AM   #16
4.30's are pretty agressive. But thats the highest id ever go..
Old 07-23-2003, 03:17 PM   #17
Gears
What do you think of a 4.88 in an 8.8.
Old 07-23-2003, 03:22 PM   #18
I woudlnt use that for steet use. I would only put it in for track use.
Old 07-23-2003, 11:32 PM   #19
4.88
A 4.88 I'd have to worry about the front end lifting off the ground, right?
Old 07-24-2003, 12:00 AM   #20
Zim
Zim's Avatar
i think your biggest concern would be topping 90 even with the rev limiter removed
I like toys
Old 07-24-2003, 10:47 AM   #21
Send a message via AIM to greenflash00
Re: 4.88
Lower gearing makes for a great boost in acceleration, but you cant replace sheer power by adding lower gears. In other words, its not once you add 4.88s that its gonna be equivalent to a cobra or anything. Dont get me wrong dude, 4.88s off the line would be insane but i really really dont think you would have to worry about the front end coming up unless you are running alot of power and have slicks. It wold becool tho to pop a wheelie at a stop light. hahahhaa
http://www.mustangmods.com/data/990/sig_2_resize.jpg
Gt takeoff exhaust with Flowtech Warlock mufflers, Mac CAI, ASP UDP, Flex Phenolic Spacers, 17 by 9 Cobra R's, 275/40s all around, FMS C-Springs, Tokico shocks and struts, FMS T-loc, FMS 4.10 gears, fordchip, 3000 stall PI tq converter, B&M Supercooler, and some various appearance stuff.
greenflash00 is offline   Reply With Quote
Old 07-24-2003, 10:57 AM   #22
4.88's will hurt your top end so much, that you're top speed will be in the 60's. And talk about a gas guzzler!!!!
Old 07-24-2003, 02:59 PM   #23
4.88
But it'd be a really fast 0-25 wooo hooo.
Sat down and read about gearing ratios for many hours.
4.10
Anything else like a 4.56 would be great off the line, but you'd slow down in top gear and max at maybe 100 max if you pushed the redline.
I'd still like to hear of someone who put 4.56 in their v6.
Know of anyone?
Old 07-24-2003, 03:10 PM   #24
4.56's? I have yet to hear of anyone putting those into a V6.
100 MPH in 5th gear redlined.... Hell, I can do that speed in 3rd
Dude, why do you want to kill your top end???????
Old 07-25-2003, 05:41 PM   #25
my speed cal will fix gear settings for the speedo up to 6.33's
Old 07-25-2003, 10:42 PM   #26
Go with the 4.10s man.. trust me i have them and they are great off the line, and the my rpms and mpg are fine. If your an auto you can get a converter as well and that will really help off the line as well. But 4.10 is really as low as you wanna go dude.
Old 07-27-2003, 05:21 PM   #27
Send a message via AIM to mattsdrag95
the thing you have to consider about a steeper gear is that the higher you go..the less traction you'll have at a launch.. you may say 'no big deal, i'll adjust,' but if you're running street tires forget about it.
if you want to seriously run anything higher than a 4.10 w/a t-lok, do the following..
1) buy an 8.8 rear
2) buy MUCH stickier tires
3) buy a TALLER tire as well.
as far as your top end goes..once you correct for the gear change you should have a chip to remove your top speed as well if you're really that concerned about it. it not a big deal and you won't be limited to only going 60mph .
honestly, top fuel guys run 6.xx gears and reach over 300mph. 31"tire and a 7-9k redline, if the "rumors" were true they could only reach 120mph.
matt
http://images.cardomain.com/member_i.../387560_89.jpg
95 ranger splash, 4.0 5-speed.
cold air, 8.8, 4.10s/t-lok, AR torq IIs and 295/50 rubber, custom traction bars w/james duff traction bars as well. flowmaster exhaust w/turndown.
line lock, 190lph pump, an fuel lines, aeromotive FRP, nitrous system, solid engine mounts, a driveshaft loop, and some 27x14"slicks
1.9 short times
13.989@97mph
257rwhp
359rwtq
mattsdrag95 is offline   Reply With Quote
4:10 gear help The Darkside Pre-2005 V6 Mustang 8 05-27-2009 01:52 PM
96 4.6 will not go into fifth gear duals 1996-2004 Mustang GT 10 09-05-2008 11:06 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
Aggressive camber ASSEMbler Pre-2005 V6 Mustang 4 08-11-2003 08:56 AM
08:45 AM
