Rear Squeak....Please Help!!! - Mustang Evolution
Old 07-21-2003, 12:26 AM   #1
Okay....I've had this squeaking sound come from the back of the car everytime i go over bumps, and I'm pretty much sick of it. Its driving me crazy. What do you guys think it could be? Bushings maybe? If it is, how hard are they to replace if I wanted to go with some urethane ones instead. Thanks in advance.
drzeusd is offline   Reply With Quote
Old 07-21-2003, 06:36 AM   #2
Monkey's Avatar
could be bushings, could be shocks, could be springs not on the rubber perches anymore.
if its A) you need a bushing puller to get them out, and urethane squeeks so you would need high quality greaseable urethane
B) need new ones
C) need to re-seat the springs
crawl under there and take a look. if you dont know, take it to a shop. theyll tell you
Old 09-15-2003, 06:50 PM   #3
your rear strut is loose, my 02 did the same exact thing and i carried it to ford under warranty, they tightened my rear strut and it's solved the problem ever since
Old 10-20-2003, 02:44 AM   #4
the same thing happened to me but when ever i stopped it would make a squeaking sound and before i knew i had to replace the rear rotor because the brake pad was not good on the rear right. being that i had no warranty on the bloody thing i went with slotted rotors and hawk pads. needless to say the ***** stops on a dime.
G-UNIT
JUST BLOW ME !
OMEGA7STARR is offline   Reply With Quote
Strut Squeak greenpony02 Pre-2005 V6 Mustang 14 03-09-2010 01:21 PM
Passenger side rear end squeak?? SuperDave2010 1996-2004 Mustang GT 4 03-09-2010 01:18 PM
A/C squeak Foxone General Mustang Discussion 9 11-22-2009 02:01 PM
Rear Axel Squeak a3705872 Pre-2005 V6 Mustang 2 11-19-2009 07:36 PM
body kit squeak Warfire80 Mustang Audio & Video 9 11-15-2005 11:20 PM
05:46 AM
