Will I have to replace the window motor? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 02-20-2009, 08:50 AM   #1
Sam09's Avatar
Sam09 is unknown around these parts
Send a message via Yahoo to Sam09
Question Will I have to replace the window motor?
It had been stalling halfway up and acting like it was off track or something, but now it won't go up at all.
I'm pretty sure the switches are working because the window will come up about an inch over the door...then it just quits and won't go any farther. I tried to pull it up manually while holding the switch down but no luck there either. my car is sitting in my yard with plastic over the window right now.
Is there any other fix, cuz i'm pretty sure I have to buy a new motor.
What do you all think?
Sam09 is offline
Old 02-20-2009, 09:04 AM   #2
modular2valve is unknown around these parts
Re: Will I have to replace the window motor?
sounds like the gear on the window motor is stripped, its not too bad to replace it. its a common problem in our cars. as a matter of fact i have to change one in another car lol.
96 GT- Who knows what's in it.
modular2valve is offline
Old 02-20-2009, 09:05 AM   #3
lowflyn is unknown around these parts
A trick I had to use on my 02 was to tap the motor to get it to go up sometimes....
You accomplish this by pulling door panel off.
To pull the door panel off you do these steps:
1. the cup where you pull the door closed, pull up lightly on the whole piece and it will pop out, might take a little force however. Take a phillips head screwdriver and unbolt the window switches and unhook the power mirror control connections if equipped
2. there is a plastic push pin on the front of the door panel, open the door wide and look directly beside the speaker. the trick to getting these out is use a flat head screwdriver to lightly pull out, then use a pair of needle nose pliers to pull it out the rest of the way.
3. pull up on the entire door panel, it should unhook. you will have to work the handle through the panel and push the wires back through the holes from the hand hold.
4. if you'll pull that plastic backing from beside the speaker on the front you can see the window motor inside the door itself, tap on this lightly with a screwdriver or something and push the up button at the same time
See if this will fix your problem, if not you already have the door apart to replace any parts that may be broken.
lowflyn is offline
Old 02-20-2009, 09:25 AM   #4
Sam09's Avatar
ok, thanks guys!
Sam09 is offline
Old 02-20-2009, 10:18 AM   #5
If you have any questions with removing the door panel feel free to post up. I had a write up on here somewhere on how to do it...gonna see if I can find it for ya.
lowflyn is offline
Old 02-20-2009, 10:19 AM   #6
Well I thought I had one...but here's one from Fast64. Jimmy's article should work well.
1994-2004 Mustang Door Panel Removal
lowflyn is offline
Old 02-20-2009, 10:25 AM   #7
USMC Roush's Avatar
USMC Roush is unknown around these parts
Send a message via AIM to USMC Roush Send a message via MSN to USMC Roush
Yeah the window motors are to much of a hassle to replace, i've done a few, the worst was my friend BMW 325 that was a pain in the ass because it was all riveted into the support frame of the door.
should be about an hour job as long as there aren't any huge complications
United States Marine Corp OIF/OEF 2009 - 2010 - Yellow 2003 Cobra: RAI, BBK mid headers, 2.81 pulley, BBK o/r X pipe, Borla Stinger Exhast, cross drilled and slotted front/rear rotors...next thing to come is color matched calipers. (still needs to be installed but it's waiting for me)
USMC Roush is offline
Old 02-20-2009, 10:47 AM   #8
jimmy_beaner's Avatar
jimmy_beaner is unknown around these parts
I will probably end up replacing my window motor and regulator when it gets warmer out... I'll be sure to do a how-to on it. It looks relatively straight forward.
jimmy_beaner is offline
Closed Thread
Power window motor Foxone Pre-2005 V6 Mustang 16 02-10-2009 01:56 PM
Window washer motor Scut95 1979-1995 Mustang GT 0 11-20-2007 08:59 PM
Power Window Motor Pizon Pre-2005 V6 Mustang 8 05-16-2007 10:19 PM
Window Motor Pizon Pre-2005 V6 Mustang 6 05-04-2007 11:35 PM
driver side window motor / switch ? Dark02Pony Pre-2005 V6 Mustang 2 06-21-2005 10:02 PM
05:56 AM
