00 3.8L trans help!!! - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 02-20-2009, 11:56 AM   #1
jaiveson is unknown around these parts
Exclamation 00 3.8L trans help!!!
ok so my trans will go into P N and R and you can drive backwords in it. but it wont shift or do anything when in 1 2 or D. ive looked around and i cant even figure out what kind of trans even goes in the damn thing. its been sitting in my garage for a couple months. anyone know what could be the problem or what kind of trans it is? its not the fluid level i know that....
jaiveson is offline
Old 02-20-2009, 12:06 PM   #2
Senior Member
SimplyOrange is unknown around these parts
Re: 00 3.8L trans help!!!
ok, it could be the adjustment on the linkage...if not, then its a burned drive band, gonna be pricey to fix, prolly be better off finding a used transmission, play with the linkage first.
SimplyOrange is offline
Old 02-20-2009, 04:18 PM   #3
bbunt302's Avatar
bbunt302 is unknown around these parts
The transmission is a 4R70W. You should be able to find one cheap at a junkyard. They were in the V6 Mustangs from 1996-2004, so they're readily available.
Scary stuff.
bbunt302 is offline
Old 02-20-2009, 11:59 PM   #4
Senior Member
they were also in v8 mustangs with slightly stronger parts, so a 99-04 gt will work too
Old 02-21-2009, 03:47 AM   #5
bbunt302's Avatar
After further research, I was wrong. All 96-04 Mustangs use versions of the 4R70W.
BUT... the bell housing pattern is different between the V6 and V8 versions. You CANNOT swap the bellhousings on the 4R70W because it is a part of the case itself. So, you will have to have a V6 version of the transmission. You can tell which is which by looking at the bolts around the starter flange, if there are 2, it's a V6 model.
Besides, the only difference as far as strength goes between the V8 and V6 models goes is a single less clutch plate in the V6 models and a difference in pressure plates. If you are worried about the performance of the transmission, check this site out: Upgrading Your AOD-E/4R70W or AOD Transmission - Baumann Electronic Controls, LLC
There are also some differences between the year models. In '98, they started using something called a "Mechanical Diode" and are actually referred to as 4R70E's because of this. So you will definitely want a '98+ if your car is '98+.
Also in mid '02, they removed the speedo gear from the tail shaft. So, if your car does not have the speedo gear, you'll want one without the speedo gear and vice versa.
Scary stuff.
bbunt302 is offline
Old 02-21-2009, 07:55 AM   #6
slvr2000stang's Avatar
slvr2000stang is unknown around these parts
Yes you will want one from a V6 and from 99 - 04.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline
Closed Thread
Trans problems... CowPunk Classic Mustangs 8 04-28-2009 07:43 PM
New 5.0L Trans. TBone 1979-1995 Mustang GT 0 05-04-2004 08:47 PM
trans am.... lowflyn Pre-2005 V6 Mustang 7 01-06-2004 09:28 PM
Trans Am GT??? .:DarkEntity:. The Bar 10 09-17-2003 03:17 PM
12:07 PM
