window problem !?! help! - Mustang Evolution
Old 02-20-2009, 03:06 PM   #1
today i finish with the exterior o f my car and now my passanger window not work!! the driver side window works fine but the passanger window not work with any of the two switches, when i push the botton i see the interior lights dim a little bit so i think is nothing with the switches ... but i really dont know what it is
carlosc is offline   Reply With Quote
Old 02-20-2009, 03:10 PM   #2
hottcobra's Avatar
Re: window problem !?! help!
came you hear any noise inside the door when you press the switch? it soulnds like the window motor is locked up. you can try holding the window switch down and slamming the door at the same time if the window starts to work for a little bit. you need to replace the window motor. If you press the switch and you hear a bunch racket inside the door but the window doesn't move. you need to replace the window regulator.
Old 02-20-2009, 05:21 PM   #3
few days ago the same thing happen and i slam the door and yhe window start to work fine one day but know this "trick" not work
Old 02-20-2009, 06:01 PM   #4
You might have to pull the door panel off and tap on the motor. Used to do this on at least a weekly basis in my 02.
1994-2004 Mustang Door Panel Removal
Instructions on how to remove the door panel.
Once you get it removed, right behind the speaker pull back the plastic covering there. The motor is behind that, take a screwdriver or something and tap on the motor while pushing the up button, should unstick then.
Old 02-20-2009, 06:24 PM   #5
the motor is behind the speaker?? i need to remove the speaker??
Old 02-20-2009, 07:16 PM   #6
hottcobra's Avatar
if your changing the motor you will.
Old 02-20-2009, 07:44 PM   #7
jimmy_beaner's Avatar
Region: Iowa
I'm hoping I can figure it out. The Haynes manual seems to do a decent write up on it. Louis, you think the Haynes manual description will be sufficient to pull that bastard apart and get the new one in? I don't want to get half done and hit a rain storm and be ****ed.
Old 02-20-2009, 07:46 PM   #8
hottcobra's Avatar
yes it be fine. it's really not that hard
Old 02-20-2009, 07:47 PM   #9
hottcobra's Avatar
if you can swap your intake. the window will be w breeze
Old 02-20-2009, 08:00 PM   #10
Region: Iowa
don't put doubt in my head the day before the install!
Old 02-20-2009, 08:03 PM   #11
hottcobra's Avatar
you can do it!
Old 02-20-2009, 08:12 PM   #12
Region: Iowa
you can do it!
atta kid! Thanks. Though it's supposed to be -1 with 2-4 inches of snow for tomorrow...
Old 02-20-2009, 08:14 PM   #13
hottcobra's Avatar
that's why I'm proud to be a southerner.
tomorrow's high is 67*
Old 02-20-2009, 08:15 PM   #14
Region: Iowa
in due time my friend... in due time.
Old 02-22-2009, 05:27 PM   #15
i do that and the window if working , like it should.....
but this ir normal sometimes or i need a new motor??
Window help if possible Foxone General Mustang Discussion 4 12-03-2008 08:47 AM
Power window and lock problem need help blzfan1963 Pre-2005 V6 Mustang 3 08-08-2008 06:35 AM
power window problem HELP !!!!! wvstang5.0ho General Mustang Discussion 7 07-08-2008 08:56 PM
HUGE WINDOW PROBlEM, NEED ADVICE FAST!! Rollin Thunder 1979-1995 Mustang GT 0 04-21-2008 12:37 PM
04:07 AM
