camshaft positioning sensor - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 10-14-2004, 09:11 PM   #1
97blackpony is unknown around these parts
Send a message via Yahoo to 97blackpony
Talking camshaft positioning sensor
My car is pulling and the "check engine " turned on. I had the codes checked and it said that its the camshaft positioning sensor. I changed it and its still doing the samething. I got the codes checked again (without telling them I changed it) and it says the same thing. Can anyone help?
Thanx, 97blackpony
97blackpony is offline
Old 10-15-2004, 05:36 AM   #2
97Stallion's Avatar
97Stallion is unknown around these parts
You changed the whole sensor? Meaning you pulled the sensor and the long rod with the driven gear?
Living one day at a time!
DAMN Those are some old ass numbers!!! I need updated ones!!
97Stallion is offline
Old 10-17-2004, 02:32 PM   #3
no just the sensor another mustang owner told me my timing chain has some slack causing the sensor to think its bad what do you think
Old 06-23-2007, 06:32 PM   #4
silverstang's Avatar
silverstang is unknown around these parts
Re: camshaft positioning sensor
hey man. i just came across the same problem with my pony. i changed the sensor itself and i didnt have a chk light until i turned it off and on again and now its back. Has anyone given you some ideas or suggestions? i heard somewhere it might be the altenator going bad but i think thats questionable.
00 gt
C&L intake
H-pipe
Mach chin spoiler (still sitting in garage)
silverstang is offline
Old 06-30-2007, 05:16 PM   #5
v6procharged is unknown around these parts
what you mean ur car is pulling? i think mines doing the same thing ur talking about. but idk
v6procharged is offline
Old 07-19-2007, 05:21 AM   #6
974.2stang is unknown around these parts
When I had my engine replaced. I had the Cam position code too. My check engine light was on and all that. I you read the Haynes Manual. That sensor has to be seated just right. Go out and get a Haynes Manual. But as far as your sensor, you might not have it seated right. Hope it helps
974.2stang is offline
Old 07-19-2007, 11:40 AM   #7
could be sumthing in your trans, my was doing the same thing like you said, pulling, and my pump was out in my tranny. i just got it back today, idk if its fixed now but ill let you know when i drive it. if its the pump, my tranny rebuild costs me 1635.41, just bc a damn pump was out, but i also got a stronger and higher stall 1900.
Closed Thread
Camshaft Position Sensor Clint Pre-2005 V6 Mustang 15 02-10-2011 12:30 AM
camshaft sensor housing 98mustang2007 Pre-2005 V6 Mustang 0 01-12-2008 03:11 PM
Camshaft Position Sensor? TransAxle 1996-2004 Mustang GT 3 07-16-2007 06:45 PM
Jack stand positioning 00stang3.8 Pre-2005 V6 Mustang 6 05-27-2007 04:50 PM
Box positioning in a Convertible? Funky4.6VERT Mustang Audio & Video 2 07-26-2004 07:40 PM
08:45 PM
