Wierd-*** problem. - Mustang Evolution
Old 10-22-2004, 04:12 PM   #1
Send a message via AIM to CakeOrDeath?
Wierd-*** problem.
For the past few months when I have been filling my tank at the gas station, the freaking pump will randomly shut off after a few seconds of pumping. Sometimes a little gas will even overflow around the top of the filler. The only way I can keep it from shutting off is by just barely squeezing the handle and waiting forever for the tank to get full.
(and no, my tank isn't full, this is happening on a nearly empty tank )
Is something wrong with my filler tube or something? Has anyone else ever heard of this happening?
Thanks.
CakeOrDeath? is offline   Reply With Quote
Old 10-22-2004, 04:36 PM   #2
Thanks.
I have it happen every once in a while. All I do is kind of shift the position of the handle of the filler and adjust the angle of the filler tube and try again. Sometimes I have to adjust it more than once...but eventually it works. It all depends on the back pressure. Now, this might not be related to your problem, but I have the same symptoms every now and then and that is what I do to fix it.
EDIT: And when I have a nearly empty tank and this happens, I have to let it pump slow for a gallon or so and then it is all happy.
Old 10-22-2004, 09:41 PM   #3
Yeh..something about the angle it's put in at...
Old 10-22-2004, 10:53 PM   #4
Monkey's Avatar
If the angle of the gas nozzle is rubbing against the inlet pipe then you won't get a good pressure flow. What I always do is put it and lift the nozzle as i pull it out just a tad. This will get the flow going which will make continuing it easier.
hopefully that makes sense
Old 10-23-2004, 06:43 AM   #5
Whatever you do..be sure to finish before pulling out...
Old 10-23-2004, 09:54 AM   #6
I liek gramer
WhiteStang99's Avatar
Hell NAW! You better pull out before you finish!
Old 10-23-2004, 11:12 AM   #7
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
better safe than sorry!!
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 10-23-2004, 07:29 PM   #8
Mine has a auto shut-off lol
Old 10-23-2004, 09:51 PM   #9
03redfire cobra's Avatar
Send a message via AIM to 03redfire cobra
you have a "Wierd-*** problem"
You might want to go see an "***" doctor!
~Evan~ This smiley was named after me-->:evan:
2008 Cadillac Escalade ESV
2006 Chrysler 300c SRT8
03redfire cobra is offline   Reply With Quote
Old 10-23-2004, 10:02 PM   #10
No, hence the hyphen.
If I had a "Wierd *** problem" then I would see an "***" doctor.
Old 10-23-2004, 10:35 PM   #11
*** doctor? I'd rather go without..the doctor that is, not my ***
Old 10-24-2004, 01:33 PM   #12
Danger Dude's Avatar
Unlike the filler tubes of old that had a big tube with a reduced size hole for the pump nozzle to fit in the 94 and up stangs use a very small tube going to the tank not much bigger than the nozzle. This causes the pump to get a back pressure sensing and shuts off. It is a safety feature so you need to make adjustments to the position of the nozzle. I think what causes it more than anything is the shape or bend of the pump nozzle and how it fits doen the filler tube
Old 10-24-2004, 01:51 PM   #13
Grrrrr......
It did it again today at the same gas station.
It took like 15 minutes to fill my tank......
It's ok tho, the joy of my new Sylvania Silverstars and my new CAI (when it gets back from the powdercoaters) will cancel out the insane rage brewing becuase of this gas tank thing.
Maybe it is just their pumps, I suppose I should try a different station. I swear I never had this problem when fueling at this station when I first got my car, I dunno.
Old 10-24-2004, 02:00 PM   #14
Next time you go there take a tape measure and measure the length of the nozzle and notice the curve or bend of the nozzle and compare it to stations you dont have probelms with. Also the pump back pressure sensing unit my be set to sensitive
Old 10-24-2004, 04:34 PM   #15
Yeah, I've taken it to another station before, so I'll have to try that out.
Old 01-14-2005, 12:51 PM   #16
Ok.
I'm still having the same problem and now it has finally gotten to the point where it is annoying me enough that I'm going to try and fix it.
It doesn't matter what gas station I go to , it has the same problem.
I'm thinking that maybe one of the vent lines is kinked because I had the rubber gasket between the fuel filler neck and the tank replaced a few months ago (not at a Ford dealership) and maybe when they put the tank back on they ****ed up and bent the line.
I'm going to try and take my car in to the Ford dealership to see if they can take a look at it.
Any idea how long it will take them to do this? Can i get my car back before Monday? (assuming they only have to drop the tank and straighten out the line or something like that)
Old 01-14-2005, 01:05 PM   #17
red herring's Avatar
Send a message via AIM to red herring
I know some people's cars that do this but only at specific gas stations. Sometimes it's annoying as hell cause it takes like 15 minutes sometimes. I've had mine do it at some 76 stations. Let us know what the problem was after it's fixed
red herring is offline   Reply With Quote
wierd clank v6stang04 Pre-2005 V6 Mustang 2 10-10-2009 11:28 AM
Wierd Sound Justin 1979-1995 Mustang GT 15 12-11-2006 11:35 AM
Wierd Noise SeadudeRXP Pre-2005 V6 Mustang 6 02-13-2006 02:55 PM
A wierd little kit. Dom Mustang Audio & Video 14 06-30-2004 03:25 PM
Wierd Noise badazzstang Pre-2005 V6 Mustang 3 12-11-2003 01:27 PM
06:01 PM
