EGR Insanity - Mustang Evolution
Old 03-01-2009, 06:06 AM   #1
IMP
Angry EGR Insanity
1995 V6
I made things much worse and am now at wits end....
Original problem was hesitation and bucking at mid speed during acceleration and a P1407 code. I pulled the EGR and flushed out the exhaust side with carb cleaner- it looked relatively clean to begin with. I then replaced the DPFE, EGR Valve Solenoid, and the TPS.
Now when I try to start it, it immediately revs up to about 2000rpm and then drops off rapidly and stalls. If I give it the gas, I can keep it running at1500rpm or above so now its not driveable.
Is there anything special about installing the TPS? The other two parts were no-brainers. Any other thoughts?
IMP is offline   Reply With Quote
Old 03-01-2009, 09:53 AM   #2
hottcobra's Avatar
Re: EGR Insanity
Setting the Mustang TPS Voltage
Old 03-01-2009, 11:59 AM   #3
IMP
Re: EGR Insanity
The TPS is modular with no adjustment possible. Two bolts with no slop for movement- it is plug and play. I just tried swapping the new TPS with the old and am getting the same result so I think something else is now going on.
No matter what EGR system vacuum line or connector I pull, I keep getting the same result. Could it be that I have multiple codes now causing this condition? I've been relying on borrowing a hand-held OBD-II tool from Advanced Auto Parts, but now I'm stranded...
Old 03-02-2009, 08:28 PM   #4
USMC Gypsy's Avatar
Re: EGR Insanity
About the original problem and this is just speculation but when was the last time your fuel injectors were cleaned and fuel filter was changed? I had the same problem and the next time I filled up I just put some transmission fluid in the tank and that cleaned the injectors and then changed the fuel filter and I didnt have the problem anymore.
USMC Gypsy is offline   Reply With Quote
Old 03-25-2009, 01:19 AM   #5
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: EGR Insanity
tranny fluid cleans injectors?? what kind?
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
20 Ways to Maintain a Healthy Level of Insanity bluemustang The Bar 5 04-20-2007 08:14 PM
Let the insanity begin... PureVenom The Bar 2 01-11-2006 11:27 AM
Insanity... haha yea right Brent The Bar 5 12-01-2004 09:39 AM
NEED 99+ EGR tube hoof Mustang Parts for Sale and Wanted 2 09-13-2004 08:07 PM
09:40 PM
