Spintech Side dual exhaust? - Mustang Evolution
Old 10-23-2004, 10:15 PM   #1
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Question Spintech Side dual exhaust?
I've been looking at installing a dual side exit kit for a GT, going true dual. Anyone have any thoughts on that? I don't plan on using an H-pipe.
232stang01 is offline   Reply With Quote
Old 10-23-2004, 10:17 PM   #2
I looked at the spintech kit, you can build a custom kit for cheaper than that. I know I've looked around for my car, and you can get the mufflers for about 80 bucks a piece then get the muffler shop to build up your exhaust completely custom. As far as not using an H-pipe, do what you want, I know with my 6er a H-pipe will be on it lol.
Old 10-23-2004, 11:15 PM   #3
Monkey's Avatar
why do you need an H pipe lowflyn?? The v6 is an even firing order engine and thus does not need a cross-over pipe. You will see no gain in an h-pipe vs an x-pipe vs straight back off the headers.
232 - I suggest getting a muffler shop to weld you on some exhaust piping to the muffler of your choice and tell them you want it to ocme out the side. They will get it done and cheaper than the spintech price
Old 10-23-2004, 11:18 PM   #4
u almost stole my user name .
anyways go with the muffler shop pick out your favorite mufflers and tell them u want a true dual set up.
Old 10-23-2004, 11:37 PM   #5
232stang01's Avatar
Thanks for the input. does anyone else make mufflers with the in and the out on the same side? I guess that's about the only reason I'm looking at the spintechs anyhow.
Old 10-24-2004, 09:55 AM   #6
Danger Dude's Avatar
DYNOMAX
MAGNAFLOW
BORLA
FLOWMASTER
SPINTECH
I am sure there are others but they dont come to me right now
Old 10-25-2004, 07:04 AM   #7
Yeh I know the H-pipe won't help me any....now...
As far as mufflers... go here, cheapest I found anywhere.
http://www.hottexhaust.com/search_re...&btnSearch.y=0
Old 10-25-2004, 02:39 PM   #8
SquirrelNutz154's Avatar
Send a message via AIM to SquirrelNutz154
You guys are forgetting the fact that its extremely hard to engineer a dual side exhaust set up that doesnt rob HP. Im sure any exhaust/muffler store could fabricate up a dual exhaust set-up, but youre gonna lose HP, not gain, as a dual exhaust setup is meant to do. I'd personally go with a pre-made kit that has proof of what it does to the HP
Sponsored by Ignited Performance and Classic Design Concepts
Cardomain Site
SquirrelNutz154 is offline   Reply With Quote
Old 10-25-2004, 03:14 PM   #9
Monkey's Avatar
nah. you get straight-thru mufflers and have them weld a 45* pipe off the headers and then run the muffler and then pipes to the side. You don't need the same side enter/exit muffler design. Those rob hp easily. Just put the mufflers up near the tranny and have them do a weld job for you. very easy
Old 10-25-2004, 03:18 PM   #10
Or you could get magnapacks and run it that way...but remember, it's gonna be a pain in the *** to put your car on a lift. That's why I just bought take offs for my car.
Old 10-27-2004, 08:19 AM   #11
Getting it on a lift is not that bad. Alot of these new shops have the lifts that have arms that just slide right under. But if you go to the shops that have regular lifts..u'll just have to take two boards and put them right b4 the ramp..this will solve the lift problem.
roush2 is offline   Reply With Quote
Old 10-27-2004, 11:15 AM   #12
It's still a PITA...and I'm prolly just gonna buy gt takeoff's lol
Old 10-29-2004, 03:36 PM   #13
232stang01's Avatar
Has anyone happened to find a cheap site to get take-offs from? the best I can do is 183$ shipped, pending availability. anyone...?
Old 10-29-2004, 05:08 PM   #14
KrazyPony's Avatar
www.stangparts.com you might wanna try!
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 10-30-2004, 09:52 AM   #15
232stang01's Avatar
Just won an auction on E-bay, $127 shipped!
Thanks for all the responses.
Does anyone see any advantage in using the pace stetter H pipe adapter? I'm thinking I'll probably not use one, but any input helps, right?
exhaust
How to remove Dual Side Mirror Control Switch on 94-98? C00LAS1CE 1996-2004 Mustang GT 4 10-08-2009 07:21 AM
SpinTech Side exhaust Vee6 Pre-2005 V6 Mustang 20 10-08-2003 07:08 AM
Dual Exhaust side exit installed w/ **pics Mustang96 Pre-2005 V6 Mustang 13 07-16-2003 05:59 PM
04:22 AM
