Car sometimes bucks. Could it be my transmission? - Mustang Evolution
Old 10-26-2004, 06:50 PM   #1
NateTrain's Avatar
I have a 2002 auto V6. Only 24,000 miles on it. This is my problem. Hard to really expalin it but I'll do the best I can.
Sometimes (not always) when I'm driving and my cars in 2nd gear it somewhat bucks (seems like the car goes fwd and back a tad bit). Then the car shifts into 3rd and its fine. Its only when its in 2nd going into 3rd.
Could it be my transmission or something else? The car shifts into gears ok.
NateTrain is offline   Reply With Quote
Old 10-26-2004, 06:52 PM   #2
97Stallion's Avatar
ya, it could be a problem in your tranny. Just take it to ford and see what they say, you should still have a warrenty
Living one day at a time!
Old 10-26-2004, 07:10 PM   #3
I think i know what you're talking about...I just kinda ignore it. My car will also stick in a gear every once in a while. That's prolly cuz I'm at 49xxx miles and haven't changed my trans fluid...
Old 10-26-2004, 07:19 PM   #4
Send a message via AIM to Crispy
I should flush mine out as well, i get that little kick on the downshift from 2 to 1 occasionally, only if i let her coast down though, doesnt happen during braking.
Crispy is offline   Reply With Quote
Old 10-26-2004, 08:36 PM   #5
I liek gramer
WhiteStang99's Avatar
hey it's a nate w/ a mustang!
Old 10-26-2004, 08:41 PM   #6
might be your 2-3 accumalator, could have broken the accumalator spring
Old 10-27-2004, 05:20 AM   #7
i have a 2002 with 23k milles and it use to do that . but it was a dirty flow meter (maf) if anything is wrong in your trany its gonna (cell light) ,
the auto is full of sensors . also do a trany flush , i did one and added lucas trans oil and the shift are nice and firm
InVaDeR is offline   Reply With Quote
Old 10-27-2004, 06:18 AM   #8
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
check your spark plugs and wires. i had the same problem for the longest time, the stumbling. turns out that cylinder one was misifiring through a crack in the wire and arcing off of the engine. changed them both out and she purred like a kitten
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 10-27-2004, 04:01 PM   #9
NateTrain's Avatar
Thanks for all of your advice. I'll start with changing my plugs and flushing my fluid and see if that helps any.
Old 10-27-2004, 04:26 PM   #10
get the dtc's while your at it
Old 06-06-2006, 01:10 PM   #11
Send a message via AIM to CakeOrDeath?
Re: Car sometimes bucks. Could it be my transmission?
I am having a similar problem to what the original poster mentioned.
I drive a '95 with an auto and sometimes when i am driving between 30-40 MPH, the tranny will seem to get stuck between gears like it can't decide which to go with and the car will buck. The engine will rev around 2-3K usually when this is going on.
I dunno if it is anything serious or not. I recently had my fluid checked so I don't think that is the issue. It is strange, the bucking happens whether I am accelerating or not (although the problem tends to go away once I accelerate above 40 or so), and does it with cruise control on in the 30-40 range as well.
Any ideas?
CakeOrDeath? is offline   Reply With Quote
Old 06-07-2006, 08:44 AM   #12
slvr2000stang's Avatar
If your trans fluid is in the 25,000 to 30,000 mile range it should be changed.
Unfortuneately with an auto the best way to do this is by flushing the trans which is a bout a $115 service, but worth it.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-07-2006, 09:43 PM   #13
Best thing I ever did for mine...now if I can only get this damn tranny cooler mounted.
Old 06-08-2006, 10:32 PM   #14
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I have pics of where I mounted mine if you need them.
DarkShadow is offline   Reply With Quote
Old 06-08-2006, 10:43 PM   #15
ha that isn't the problem, finding time is the problem...
Old 06-20-2006, 10:33 AM   #16
Update:
I added some Lucas Transmission Fix to my tranny and it seems to have fixed the problem.
I am utterly shocked. I never thought it would work.
Anyway, anyone else with this problem might wanna try it before they spend $120 on a tranny flush. I got a 24oz bottle at Pep Boys for $10 and put may 1/3 of the bottle in and it has dramatically improved if not completely fixed the problem. I didn't use the whole bottle as the insturctions said becuase my tranny is already more than full, so i imagine a full bottle if used would do even better.
Old 06-20-2006, 10:38 AM   #17
you should change the tranny fulid every year on an auto, even if it is only a drain/fill. I would do an entire flush now and again though to make sure its all fresh.
Dayum, anyone checked out this USC?? 2500 bucks!! roush4life The Bar 0 08-24-2007 08:14 AM
get yourself a cobra R for only 7500 bucks! Zim The Bar 9 03-14-2006 01:16 PM
99-01 cobra fog lights 44 bucks SpectorV Mustang Parts for Sale and Wanted 3 01-03-2005 05:18 PM
Look what I just won for 5 bucks Brent Pictures and Videos 7 08-27-2004 10:10 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
10:05 AM
