!!!!Coil Overs!!!! - Mustang Evolution
View Poll Results: What Lowering Method Should I Use?
Coil Overs? 5 38.46%
Lowering springs 8 61.54%
Air Ride 0 0%
Adjustable Struts 0 0%
Voters: 13. You may not vote on this poll
Old 07-23-2003, 12:48 AM   #1
Send a message via AIM to !*!STANG!*!
!!!!Coil Overs!!!!
Has anyone instaled or does anyone know of any coilovers out there for our cars? ive found lowering springs and adjustabal struts.. but what i want are coilovers... anyone find any or have any instaled PLEASE let me know im dying over this... Thanks you!
White 95 5 Speed V6
Mods: Audiovox Head(temporary)
Future Mods: 1 JL 10W3v2 in a ported box, JVC Arsenal KD-SX9350, 4 Infinity Kappa 572.5cf, Custom True Dual Exhuast and gutted cat, SSX Sheetmetal Upper Intake Manifold, Paint, Eibach Pro Kit and Eibach Pro Damper Kit plus more im only 15 so i have pleanty of time :)
!*!STANG!*! is offline   Reply With Quote
Old 07-23-2003, 05:26 AM   #2
Danger Dude's Avatar
Coilovers are nice but I think I would go with lowering springs!!!
Corey
Old 07-23-2003, 03:06 PM   #3
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Why would you prefer lowering springs instead of coil overs? Arent' coil overs suppsoed to improve handling over the plain lowering springs?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-29-2003, 06:41 PM   #4
Send a message via AIM to slow232 Send a message via Yahoo to slow232
Correct.But it takes alot more money to do coilovers then to just buy springs.
Coilovers are about 500.00 bucks + Good shocks and struts 500.00+ CC plates 200,Then if your going to have somebody else install the stuff then your looking at about 400.00. i paid about 1200 bucks for my suspension that's including Coilovers ,shocks, struts and CC plates.I installed everything myself.
Now for springs you dont really need shocks and struts but it wouldn't hurt...also you might need cc plates but it wouldnt be a bad idea to get them.
Springs $200 cc plates $200 S&S 350 = 750
Springs do not come close the control of having coilovers.Trust me i've driven a car with h&r's with bilsteins and i drive mine with coilvers and kyb's (soon to be Koni Double adjustables) and it doesnt compare.
slow232 is offline   Reply With Quote
Old 07-30-2003, 07:53 AM   #5
Send a message via AIM to el cheapo
i have heard that you need shocks and struts if you get lowering springs. . . that your stock ones will fail within a few months once you lower it.
is this not true??? : :
if i can do springs without shocks, i might just do it by the end of summer as well.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 07-30-2003, 12:47 PM   #6
Stop being a cheap *** and get shocks and struts to go with the new springs.
Old 07-30-2003, 01:25 PM   #7
hahaha
but i cant!! i cant go against my cheep *** nature!!
Old 10-11-2003, 09:37 PM   #8
I just put in my coil over kit on the front. After 40 miles I give them the edge over springs. Just watch Ebay for a good deal. And get the shocks and struts too.
Women prefer good handling to quick rides!
gdcpony is offline   Reply With Quote
Old 10-13-2003, 08:44 AM   #9
Region: Iowa
Kenny Brown makes a coil over kit that's $1500 that replaces the stock a-frame too, and changes the wheel base by one inch. It makes it longer I believe. Any ideas on the inprovement, if any, that would make over just using the stock A-frame?
Old 10-13-2003, 11:47 AM   #10
tire's Avatar
Send a message via AIM to tire
Yes, what slow232 said.
We all have slow, cheap, V6 Mustangs. Unless you're going all out, lowering springs will be just fine. If you're building a road car or a drag car, then that's different. 95% of the people here though would be best off with lowering springs.
tire is offline   Reply With Quote
Old 10-13-2003, 11:49 AM   #11
tire's Avatar
Nothing will "fail", it just won't perform half as well as they will with matching shocks/struts. Don't sweat it, just keep a look out for some cheap tokico or bilsteins.
Old 10-13-2003, 12:20 PM   #12
Rick0636's Avatar
My car will handle better now than I am willing to take the chance to drive it, if I handled better it would just be a waste of money, and I have a modified GT, lol!!
Old 10-13-2003, 06:19 PM   #13
the ONLY reason i would get coil overs is if you are really wanting to get out there and autox and etc. cuz you will adjust them and leave them be....they cost alot more than spings. i would just buy springs and be done with it.
coil pack sledgehammer Pre-2005 V6 Mustang 13 01-13-2010 10:18 AM
ignition coil v6stang04 Pre-2005 V6 Mustang 6 01-09-2010 01:56 PM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
Lower Springs verse Coil Overs??? Sonic Blue Pre-2005 V6 Mustang 6 04-30-2006 11:03 AM
coil overs vs. lowering springs STEVE Pre-2005 V6 Mustang 6 06-13-2004 02:36 PM
04:48 AM
