radiator leaking! yay :S - Mustang Evolution
Old 03-06-2009, 12:14 PM   #1
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
alrighty, well i found out why my coolant light came on twice now, first time i thought it was a fluke, my radiator seems to be leaking from both ends somewhere (where the fins meet the end parts) so i'm going to go take some stuff off and see if i can locate exactly whats going on, wish me luck! (its finally sunny here so its now or never)
bloodyspirit058 is offline   Reply With Quote
Old 03-06-2009, 01:09 PM   #2
Region: Oregon
Re: radiator leaking! yay :S
alrighty, well i went and took off the top plastic thingy, and half of the fan so i could get a better look, looks like the yellow stuff (sealant?) is totally trashed down on the bottom compared to the top (i don't usually play with radiators so i'm not exactly sure what its supposed to look like, but compared to the top it looks like its not sealed)
any suggestions on replacing a radiator that will make my life easier? i might as well put new hoses on too...
on a side note... there is a bracket that goes over the radiator, over the fan, and just past the resivoir and attached is a little box that kinda looks like an ecu, what is that? i figured abs cause below is some other box thingy that says abs, but it might also be for the ford installed alarm, not sure :S ill take a pic if i think about it later.
Old 03-06-2009, 07:13 PM   #3
Region: Oregon
well i got all the parts off, its a little tricky specially since i thought it would be easier than a saturn... oh well, new parts will be purchased 2morrow.
Old 03-07-2009, 06:49 PM   #4
Scut95's Avatar
It's not too bad of a job. I did this about a year ago. Just make sure the new radiator is in the mounting gromets straight and you're good to go. It's a simple straight up swap. If you need anything just let us know.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 03-07-2009, 07:25 PM   #5
Region: Oregon
ya, i was kinda pissed at first cause i just bought the car, from a dealership no less... and i was thinking it was going to be a huge deal. getting it outa was kinda a pain, but it all went back in flawlessly.
the one i got was for an auto though, so i just plugged the holes just in case. but its all back in and seems to be doing fine. thank you though.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
Old 03-07-2009, 08:06 PM   #6
MonteCitan's Avatar
You should be good to go, then.. Radiators aren't a huge deal, unless they flat out die on you when you're not in a convenient area haha
Good luck
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-08-2009, 12:55 PM   #7
Region: Oregon
Good luck
ya, i think i was just expecting more of a hassle, the weather has been a mix of pouring rain, and light rain. but it cooperated enough for me to get it done so all is good. now hopefully the next time i put money into it will be for some mods instead of repairs
Leaking rear Calumus 1996-2004 Mustang GT 4 09-19-2008 04:41 AM
Leaking Exhaust Manifold? 00vertstang Pre-2005 V6 Mustang 8 06-04-2005 07:16 PM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Leaking Transmission Fluid?.. Ibanezplayer272 Pre-2005 V6 Mustang 20 09-07-2004 02:40 PM
07:44 AM
