Too much Transmission fluid? - Mustang Evolution
Old 11-27-2004, 03:10 PM   #1
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
I think I might of found out why my shifting is a little rough (auto), to much fluid, what would be the best way to get some out, probably just get under, unscrew the pan and let some leak out?
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 11-27-2004, 05:30 PM   #2
just check the manual on how to read the dipstick. to drain it you just unbolt the back bolts of your trans pan and then a couple on the sides and some will drain out after you think its been enough check it how the manual says and add as nessesary.
Old 11-27-2004, 05:54 PM   #3
drain it all that way you can get yourself an oil change while youre at it, then just put in what the manual says.
changing automatic transmission fluid 007z28350 Pre-2005 V6 Mustang 8 08-30-2009 01:25 AM
Transmission Fluid Smell Rainman64 1979-1995 Mustang GT 3 07-25-2009 09:08 PM
Transmission Fluid Mustangfan2003 1996-2004 Mustang GT 5 04-28-2009 07:52 AM
Changing transmission fluid electricstang Pre-2005 V6 Mustang 4 12-16-2005 02:11 PM
Leaking Transmission Fluid?.. Ibanezplayer272 Pre-2005 V6 Mustang 20 09-07-2004 02:40 PM
03:46 AM
