5.0 Maintance - Mustang Evolution
Old 11-30-2004, 05:40 PM   #1
StreetRacer4371's Avatar
5.0 Maintance
My car has 150,000 mile and I want to put some chemicals in my transmission fluid and oil when I change them. Any suggestion on a certain type or brand.. Anything helps...
http://www.mustangevolution.com/foru...ine=1102399529
Its not revenge... Its PUNISHMENT
StreetRacer4371 is offline   Reply With Quote
Old 11-30-2004, 06:44 PM   #2
01mineralgrey6's Avatar
Ive heard good things about "Lucas" may want to give them a look.
-Tony
'99 cobra 'vert
Old 12-09-2004, 09:33 PM   #3
MonteCitan's Avatar
I have a vendetta against additives - especially in engine oil, adding something to a specific blend of oil (with the right mix of detergents/etc) can throw the balance off and work against you - also saw an article where someone tried churning oil.. identical oil, but with the lucas additive foamed right up compared to the stock oil, which stayed mostly as it should...
Old 12-31-2004, 05:47 PM   #4
at 150k with out using full synthetics and what not be saving for a rebuild
Old 01-02-2005, 09:37 PM   #5
I use Valvoline max life 5w-30 on mine and I add Lucas stabilizer once a year during the summer(it makes the oil thicker and in the winter the valves tick from it). So I would wait until it gets warmer out. But it did help my motor run better and smoother. I currently have 105,000 on mine.
89'FIVE-O is offline   Reply With Quote
Old 01-02-2005, 09:41 PM   #6
during the summer i use 10w-30*
Old 01-02-2005, 09:41 PM   #7
in my expirience lucas works wonders for transmissions, what i like to do is add lucas to the tranny while i change the oil and filter, then 30 days later change the oil and filter again but without adding lucas. lucas is not meant to hold up as long as ATF
Old 01-03-2005, 02:12 PM   #8
ive heard good stuff, but since i have a manual i havnt looked into it.
Old 02-24-2005, 09:43 PM   #9
silverstangboy's Avatar
yeah, ditto, if your having problems with the motor, a brand called motor honey will work wonders but its thick, i'd only do this with a high mileage motor that doesn't have long before a rebuild, like maybe one with leaky heads
93 mustang notch
~450hp 331 stroker - Sold
11:20 PM
