Running Hot - Mustang Evolution
Old 03-31-2009, 04:26 PM   #1
Running Hot
1987 5.0 5speed 302 basicially stock. I have checked thermostat in a pot of boiling water, new serpentine belt, adjusted,. Fill radiator, go for a ride. About 15 miles,reading 180, 15 more miles 180 and then it starts going higher and higher, when it gets to 220, I stop and let it cool,add about 1/2 gal water, go home. Next day, same routine,same results. HELP:
Gray Ghost is offline   Reply With Quote
Old 03-31-2009, 09:08 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Running Hot
Well, if you have to add a 1/2 gallon of water, I'd say you have a leak. Make sure the radiator and hoses are good, and make sure there isn't any coolent leaking out of the weep hole of the water pump.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-01-2009, 07:47 AM   #3
SaleenFiend's Avatar
Re: Running Hot
Check for signs of leakage with the heater core (wet pass floorbard, water leaking under car near chassis. Do you smell coolant? I would say check your fans, but the coolant is leaking obviously. Where are you located.
When you fill the system make sure that you burp it correctly (work all the water out) if you need help with this let me know.
Old 04-01-2009, 07:49 AM   #4
Re: Running Hot
yea i suspect it being the heater core. does the windsheild fog up a little? check the floorboard on the passenger side, do u smel coolant or water in the car?
96 GT- Who knows what's in it.
Old 04-01-2009, 09:21 AM   #5
Re: Running Hot
I'm in western NC. Tks
Old 04-01-2009, 09:23 AM   #6
Re: Running Hot
The windshield fogs very little, Going to check heater core. Tks
Old 04-01-2009, 09:24 AM   #7
Re: Running Hot
Going to check heatercore. Tks
Old 04-01-2009, 09:37 AM   #8
Re: Running Hot
yea im sure thats the problem. the only thing that sucks is the dashboard will have to be removed or moved back enough for the heater core to come out.
Old 04-01-2009, 10:56 AM   #9
Re: Running Hot
Its a BIATCH
Old 04-04-2009, 08:30 AM   #10
Titus Wadicus
svtlx's Avatar
Re: Running Hot
Originally Posted by SaleenFiend View Post
Its a BIATCH
i second that motion....sucks very much bad!!!!
Old 04-04-2009, 10:00 AM   #11
Re: Running Hot
Got it fixed. It just needed a new radiayor cap. appreciate all the help.
Old 04-04-2009, 11:04 AM   #12
MonteCitan's Avatar
Re: Running Hot
Glad it was a nice easy fix!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-14-2011, 12:00 AM   #13
94 Mustang GT's Avatar
Re: Running Hot
If its a heater core easy test would be turn the fan on max at vent and just smell for coolant! lol
94 Mustang GT is offline   Reply With Quote
Old 01-14-2011, 12:02 AM   #14
Re: Running Hot
The boiling pot o water certainly works, but an easyier way just little more time is turn the car on (when cold) and feel the upper radiator hose. If it goes from reg temp to super hot real quick it works fine, but if it gradually warms up over time its stuck open. Just lettin you know another way to test it!
what should i be running? tigercrazy718 General Mustang Discussion 0 05-19-2010 02:31 PM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
We got them running now Brent The Bar 7 02-14-2007 06:46 AM
Running the V-6 05STANG Pre-2005 V6 Mustang 5 02-13-2006 07:36 AM
Running Hot.... Shortie630 Pre-2005 V6 Mustang 12 03-25-2004 10:19 PM
04:08 PM
