92 Mustang replacing front cailpers - Mustang Evolution
Old 04-05-2009, 09:06 PM   #1
Anyone here have driveway experience replacing front calipers on a 92 era stang?
I'm have the how-to books, but just curious if I would have a back up here in case
I have a new set on the way, I got brake cleaner, tools, will need to see if my hex fits for the caliper removal. I also bought a small bleeding kit, never bled the brakes on my own before...
I neglected to order new brake lines, wondering if I should spring for some braided ones or just normal rubber ones...
CreationNation is offline   Reply With Quote
Old 04-06-2009, 01:17 AM   #2
Scut95's Avatar
Re: 92 Mustang replacing front cailpers
Basically changing calipers is straight forward. Make sure to get the banjo bolt back on properly and you will need to bleed all 4 brakes afterwards. Start with the brake that is farthest from the master cylinder and work your way to the closest, making sure the master cylinder is topped off every 3-5 pumps of the pedal. If you don't you will suck in air and defeat the whole purpose and you will never get the bubbles out. Rubber brake lines will be fine for street use. If you need the lines, now is the time to do it otherwise you are going to have to bleed the brakes again. If they are in good shape, then you don't necessarily need to do them.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 04-06-2009, 04:42 AM   #3
bbunt302's Avatar
It's pretty easy. The banjo bolt is probably the most important part. You have to be VERY careful not to strip the bolt or you could ruin the caliper. As far as the bleeding, just be sure that you actually do it long enough to get the pedal nice and firm. Also, test the brakes BEFORE you start heading off down the road.
Scary stuff.
Old 04-06-2009, 06:46 AM   #4
My brakes lines are dry rotted so I have to replace for sure (otherwise yes I would reuse).
So all 4 brakes need to be bled even though only replacing the front, correct?
EDIT: Just found a set of "Dryrot Resistant Rubber Compounds & Corrosion Resistant End Fittings" brake lines from NAPA (where I ordered the caliper sets)
Old 04-06-2009, 08:56 PM   #5
Scut95's Avatar
Yes, you still need to bleed all 4 brakes despite only changing the fronts. Start at the farthest from the master cylinder (passenger rear) and work your way to the closest brake to the master cylinder (driver front). Basically it goes Pass rear, Driver rear, Pass Front, Driver front. Just make sure your fluid is topped off or you will suck in air. And as Bbunt said, pump the pedal a few times before you even start the car and take it for a test drive otherwise you won't have any brakes!
95 GT- Sold
Old 04-07-2009, 06:15 PM   #6
So my Mustang sat for a while before now, and my rotors look like this:
Will that top rust/weathering go away once I get driving it again, or am I looking at something I have to have turned?
Old 04-07-2009, 06:47 PM   #7
bbunt302's Avatar
You should only have to have it turned if there are grooves in the rotor. The rust will come off quickly once you start using the brakes.
Scary stuff.
Old 04-15-2009, 04:19 PM   #8
SaleenFiend's Avatar
Yes anytime you replace front pads you should have the rotors resurfaced @ your local parts store.
Old 04-18-2009, 10:01 AM   #9
Thanks for all your guidance on this guys, went well, bleeding was pretty simple as well as the install.
Old 04-18-2009, 07:37 PM   #10
MonteCitan's Avatar
Good deal, I love it when a project goes well!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
cai
Supercharging and replacing rear axle and gears for my mustang 2008 bmx_20055 Pre-2005 V6 Mustang 25 02-07-2009 09:06 AM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
Replacing U-joints? Ibanezplayer272 1979-1995 Mustang GT 13 11-11-2005 07:16 PM
Stage 3 roush front OR keep 01 cobra front? SpectorV Mustang Audio & Video 16 11-27-2004 12:17 AM
» Members Mustangs
GT
MHochhaus
Sally
SallyV6
Add your Mustang
10:43 PM
