pushrod length - Mustang Evolution
Old 12-13-2004, 02:22 PM   #1
pushrod length
If I get roller rocker arms with 1.7 lift will I have to get different length pushrods? I was looking to get the Ford Racing Cobra rocker arms.
89'FIVE-O is offline   Reply With Quote
Old 12-20-2004, 08:04 PM   #2
97Stallion's Avatar
no, you should be able to use your stock push rods. What's your stock rocker arm ratio: I believe it's 1.6:1. It's just like our V6's we can use 1.73:1 or 1.8: rockers and the same pushrods. The bigger ratio just gives you a little more lift.
Living one day at a time!
Old 12-31-2004, 05:44 PM   #3
yea you can probably run the stockers... but it may be good to replace em while you are at it...
Old 01-02-2005, 09:48 PM   #4
I actually have a Grand Marquis with the non H.O. motor so im pretty sure the lift is only 1.5
Old 02-24-2005, 09:51 PM   #5
silverstangboy's Avatar
1.5!?!? didn't know they're was such a demon, yeah, depending on brand you might or might not have to change pushrods, FRPP's uses the same as stock, and they are decent roller rockers, just get ready to do some grinding on the vavle covers, and it wouldn't hurt to check piston to valve clearence, nore check valve train geometry while your at it...
google (correct valve train geometry) get ready to have some fun
93 mustang notch
~450hp 331 stroker - Sold
Old 09-17-2005, 12:11 PM   #6
Re: pushrod length
check your rocker geometry!! any changes will affect this including simply adding screw in studs ,guideplates, and 1.6 rockers.
check for proper clearance between rocker and retainer, rocker and base of screw in stud, and contact pattern on the valve face.
Dont resort on asking others to guess your setup- a simple valve job, or different head gasket can even mess things up.
kurt herold is offline   Reply With Quote
99-03 v6 to pushrod v8 conversion questions..anyone help svtlx 1996-2004 Mustang GT 0 02-26-2009 05:20 PM
Modular Vs Old School Pushrod EVILUTION GhosT 1979-1995 Mustang GT 2 01-03-2008 05:57 PM
Pushrod length snake428CJ 1979-1995 Mustang GT 1 08-13-2007 09:12 PM
Congrats to Fast64 our new Pushrod Moderator Brent ME Site Help & Announcements 12 03-31-2005 04:40 PM
06:21 PM
