Hey guys im new here i was wondering i got a B cam layin around its out of my old 302 i was wondering would it hurt anything if i put the used B cam in my new 302? thanks
the cam on a 5.0 is a really straightforward swap, if u did the heads u can definitely do the cam. u can remove the water pump and timing cover as one assembly if i remember correctly to save time. itll take a few hours but its definitely worth the swap as far as power and sound.
sweet and thanks for the tip on saving time thank god this car isnt my daily driver any more so i can take my time doing the work it took me forever to do the heads cuz work was slowing me down but now i can do it on the weekend and again thanks :good:
yea its a straight forward swap, take off the intakes, timing cover,water pump and the front accesories needed. If the gasket on the water pump to timing cover is good still you can remove them together.
How many miles on the motor? putting in a new set of lifters wouldnt hurt either.
im not sure how many miles is on the motor but all the gaskets were replaced about 25k miles ago i bought the motor with 75k on it then replaced the gaskets b4 i put it in the car
save it, this is useful:good:
headflow #'s for SBF's
ive actually put several of these to the test on my buddy's superflow flowbench and they are accurate
b-cam will work in a completely stock engine. other than sound, a cam in a 5.0 will do nothing! you're gonna need aftermarket heads or at least good ported E7TE's. the best thing you can do for a 5.0 besides forced induction is heads. the stock heads are anemic! on mostly stock engines, as far as off-the-shelf cams, ive always preferred TFS stage 1's. they can be picked up anywhere cheap. i know crane made the TFS cams and since crane has gone under, little is known about who is gonna make TFS cams now.shot, and bolt ons.
just curious, on a 94/95 gt, what are the heads called? i don't know all the little stuff about my car yet i know it has the funny angled plugs, was just curious if it was the same as the explorers or slightly differnt
the heads on our cars stock are E7TE heads. thats just ford's code for the engine. if you look at the bottom right corner by the oil pan and where the bell housing meets, itll have cast in it "E7TE". i discovered that the other day
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
