351C 2v - Mustang Evolution
Old 01-09-2005, 08:28 PM   #1
Send a message via AIM to mild2002gt Send a message via MSN to mild2002gt Send a message via Yahoo to mild2002gt
351C 2v
i have a 351C-2V in my 69 coupe (stang) backed by a C4. I have headers, 600(soon to change to a holley dp 750).
what are some good, yet not too expensive, mods that i can do to it?
btw...does anyone know someone in the DFW area that can install my 70 glass in the 69, thanks!
mild2002gt is offline   Reply With Quote
Old 01-17-2005, 01:19 AM   #2
Tbird232ci's Avatar
for a 351c, cheap mods are hard to come by, do you have anything done in relation to ignition?
Old 01-17-2005, 05:17 PM   #3
fast64's Avatar
how about an edelbrock intake to go along w/ that holley carb?
GO BRAVES
Old 01-17-2005, 06:18 PM   #4
i have an eldebrock intake already.
as far as the ignition, i have new ignition and starter solenoids
i have a MSD blaster coil
i also have an azure blue paint job
15 inch chrome steelies
and M/T valve covers
no REAL mods except the eldebrock intake
Old 01-17-2005, 09:17 PM   #5
Tbird232ci's Avatar
are there any roller rockers available for the 351C?
the only real "cheap" mods you can do without getting too involved is:
MSD ignition box and coil
headers
exhaust
intake manifold
carb
roller rockers
big air cleaner
a good tune
and you already have most of that listed, from there on, its more expensive and involved stuff
Old 01-17-2005, 10:02 PM   #6
Rick0636's Avatar
The best of all mods for a 2v cleveland is a set of cleveland 4V heads, but they are hard to come by I imagine and probably go pretty high if you can find them. But then that Edelbrock wouldn't fit anymore either, the 4v edelbrock for the 2v clevland won't fit the 4v heads. If you get lucky and find some 4v heads you can afford, then go crazy and have those badboys ported out and polished up as nicely as you can afford to, and watch the difference in how well that Cleveland will run, also get a 3 or 5 angle valve job while you are at it.
Old 01-18-2005, 04:38 PM   #7
i have headers(hookers, ..i think)
eldebrock intake
600cfm, but bought a holley 750 dp to put on instead, just needs rebuilding
flowpro exhaust
air filter is K&n style(rewashable) with chrome top and bottom(just so ya'll know it's not just the filter)
Old 02-24-2005, 09:30 PM   #8
silverstangboy's Avatar
change the cam they're have been a few advancements in cam design since the late 60's, they're may even be a solid roller conversion that you can get with the cam ( and yeah this is a cheap mod, just alot of labor) if so then you can get even wilder with ramp rates and the such... also i believe they're are a few ways to change to electronic ignition, this will pick you up some gas mileage, an MSD varible ignition system will help you pick up a little mileage and add power, noticible power, but thats not really my idea of cheap
I grew up building a 408 windsor, good times good times. 2v cleavelands are low velocity high flow heads, if you plan on keeping this car when you do get money to work on it, a stroker kit (yeah they have them for cleaveland now) would really make a night and day difference, more cubes, less rpm.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-03-2005, 06:08 PM   #9
yeah, i saw the other day that there are some 408 stroker kits available. Heck back when i started working on it a few years ago, there was hardly anything out unless it was at an outrageous amount of $$$
Old 03-04-2005, 06:03 PM   #10
RGR
Send a message via AIM to RGR
Without a cam change, keep the 600 Holley. Even with many cams the
600 is better, a 750 DP flows more than a 750 vacuum Secondary, which
is better matched for a 351. (vacuum sec) The 600 is good up to 400 BHP
so stick with that.
I can spec you a cam and pick a close aftermarket one.
Get a modern cam with fast ramps and that thing WILL
need the 750 DP! Mild Head porting is a good idea, and
more CR always helps.
They make lots of RR's for that, you could get 1.8's and
get more valve lift with the stock cam. I can make you a
conical valvespring conversion, but that would need a cam
change to make full use of it.
Roller Cams ROCK! Do that if at all possible. But it is not "cheap"
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-04-2005, 06:18 PM   #11
RGR
I beg to differ, the 4V heads are way huge for an engine OVER 400 cubes.
A good compromise IMO is 4V intake valves in the 2V heads. It helps the
short turn (if you cut the bowls right) and the exhaust valve is already a
1.65" which is huge, but the 4V has a 1.71" Exh!
Intakes:
2V = 2.04"
4V = 2.19"
Exhausts:
2V = 1.65"
4V = 1.71"
Got a guy here in town that makes econo-strokers,
has made Clevelands up to jsut under 400" with
easy to find parts, and has went well over 400"
with higher dollar parts. He is the stroker king,
but has a long waiting list. He made perhaps the
world's first 408 W, 2 years before John Vermeersch
(SuperFord's FACTORY HOTLINE columnist) said you
could not do it
He put 2V heads on that 408W, it was very torquey!
Old 03-06-2005, 10:51 PM   #12
I'd imagine so, what components made up this 408? possibly a certain dodge crank?
93 mustang notch
Old 03-07-2005, 06:03 AM   #13
RGR
It was 100% Ford factory and Ford Aftermarket componentry
He used a 400M crank, stock rods from a certain FORD V8 (C or W, I forget)
and 302 forged pistons, I believe he milled the tops for compression height.
It was non-power adder so the thinner tops were no problem. External
balance, that saved some money.
351W, 351C, 351M 351mod_stang 1979-1995 Mustang GT 3 07-19-2008 08:59 PM
351C 2V vs. 4V? MaresMotorsport Classic Mustangs 3 06-15-2008 01:55 AM
01:05 AM
