Odometer & trip meter - Mustang Evolution
Old 05-05-2009, 10:31 AM   #1
On the 94 & 95 Mustang ,if you take the speedometer,tach apart, on the back of the guage cluster at the bottom, you have the plastic gear case that drives the Odometer & trip meter. These gears wear out and break. Directly under the electric drive gear is a black gear that turns the numbers. Now for the problem, my black gear is broken. I need the enclosed gear case which is attached with three screws. ( Don't try to remove the gear itself, it will most likely break ) Help will be appreciated.
Gray Ghost is offline   Reply With Quote
Old 05-05-2009, 11:16 AM   #2
bbunt302's Avatar
Re: Odometer & trip meter
You should be able to hit up a junkyard and see if they have anything.
You also might check out these guys and see if they can help: MPS Auto Salvage
Worst comes to worst, you can just buy an entire instrument panel.
Scary stuff.
Old 05-05-2009, 04:01 PM   #3
Cobra GT's Avatar
This is a problem with most late model Fords. You should change both gears; there is a white worm gear that goes with the black one. Some aftermarket companies have made improvement of the material these gears were made out of. Here is a link where you can get them, $40. They have them for cheaper but be weary, I can’t the find the site that manufactures them, and they guarantee that the material they use will last. Good luck.
Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
Odometer Gears and Speedometer Gears for Ford and Chevy
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 05-05-2009, 05:51 PM   #4
Thanks Cobra GT. The site is Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478. Ordered as soon as I found them.
Junkyards, are not avery good source. I tried 5 clusters and couldn't find a good one. The ones I tried, were mushy and gooy. I think Ford should pay the bill.
Old 05-05-2009, 07:21 PM   #5
Cobra GT's Avatar
thanks for the thanks, yea they get mushy after awile, that is retarded i had the same problem with the GT and the Cobra, there are tutorials on the subject too.
1996 GT (sold)
1997 Cobra
Want an 03/04 Cobra
Old 05-07-2009, 08:31 AM   #6
yep, those guys hit the nail on the head. its a breeze to change.
iamdat is offline   Reply With Quote
Old 05-08-2009, 09:51 AM   #7
SaleenFiend's Avatar
Yeap I totally agree
waits for thanks...
Old 05-08-2009, 02:45 PM   #8
I gotta freebie!!
odometer and Trip not working Tim Knox 1996-2004 Mustang GT 2 07-19-2008 12:12 AM
odometer 98mustang2007 Pre-2005 V6 Mustang 2 03-28-2008 04:14 PM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
What does your Odometer read? DarkShadow General Car Discussion 54 06-18-2007 09:53 PM
Auto Meter D-PIC Performance Meter Dom Pre-2005 V6 Mustang 15 01-07-2005 03:35 PM
06:29 PM
