Freon - Mustang Evolution
Old 05-19-2009, 03:59 PM   #1
Freon
Please share with me how to install freon in a 95 5.0 Tks
Gray Ghost is offline   Reply With Quote
Old 05-19-2009, 04:01 PM   #2
hottcobra's Avatar
Re: Freon
do you have a slow freon leak and you were told to just freon?
Old 05-19-2009, 05:15 PM   #3
Otlaw80's Avatar
Re: Freon
If your A/C isn't working cause your low on freon (is that how u spell freon, it looks funny) , then you have a leak and its not worth spending the money to refill, without finding the leak and fixing it. But, if you want to give it a shot you can usually find a refill kit at your local parts store and it will have directions on the can. Good luck.
Old 05-19-2009, 11:47 PM   #4
Cool Re: Freon
reclaim all of the original freon r134a and then do a leak search and repair if ness. Then put the freon lines in to a vacumn for 15 min or so. Then add in r134a or ur spec. freon. Put it in by weight. That is the right way if any. If you want to just top off freon level then I would turn on a/c full blast for 5 min or so. Get a Walmart freon bottle with gauge and connect the bottle and guage to the suction side freon schrader port. When your compressor comes on then check your guage reading. Low, Good or High. Your looking for a general level of "good". If low then with the compressor on and your bottle connected squeeze the bottle trigger for 3 seconds or so. You can turn bottle left and right but dont tilt all the way. Just a slow shake left and right. Let off of the bottle trigger and see what your pressure reads. If to much then release some according to code. Dont be scared of it at all but then again dont over feel. There is a balance and a happy medium. I would also get a thermometer and test for 50-60 degree air coming fron vents with a/c on. HOPE THIS HELPS
95svt is offline   Reply With Quote
Old 05-20-2009, 11:02 AM   #5
Re: Freon
thanks for the help, but it is now fixed and good and cold.
07:25 AM
