changing oil pickup, how to prime it? - Mustang Evolution
Old 02-16-2005, 08:54 PM   #1
fast64's Avatar
the oil pan on the 90 motor is a dual-sump pan and i need to put a front-sump pan on it to put it in the 64, so i will need to install a new oil pickup tube. how do i prime the tube?
GO BRAVES
Old 02-24-2005, 08:49 PM   #2
silverstangboy's Avatar
thats simple, take a drill or an impact wrench, get the correct size socket and attact it to the shaft that drives the oil pump from the top side of the engine (be careful! don't drop any parts down there) turn turn turn, it'll prime itself, it doesn't hurt to fill the pickup with a little oil while your putting it together either
yes the engine should pick up oil on its own when you start it,... but.. you really want it to have pressure way before the amount of time it takes to prime
93 mustang notch
~450hp 331 stroker - Sold
Old 02-24-2005, 08:51 PM   #3
um, well it doesn't look like thats really what your trying to ask about, regardless, you can't prime it that much, I just turn the motor upside down and fill the tube up after its attached to the pump, it won't all drain back out once the motor is turned back around.
93 mustang notch
Old 04-21-2005, 05:49 PM   #4
Send a message via AIM to chevyslayer5.0
i always open up the pump and coat the gears with some assembly lube to prevent friction damage. And then prime the pump with a drill on the pump shaft with a full oil pan.
RICE IT'S WHATS FOR DINNER
chevyslayer5.0 is offline   Reply With Quote
Old 04-21-2005, 05:51 PM   #5
but u cant really prime the tube i miss read your post. If u didnt replace the pump ignore what i said. Sorry man.
Changing my blower oil, any tips SpectorV 1996-2004 Mustang GT 5 04-07-2006 12:22 PM
About changing oil... Ibanezplayer272 Pre-2005 V6 Mustang 21 02-23-2006 09:33 PM
Oil changing questions. For a mod newb saleen0027 1996-2004 Mustang GT 22 07-15-2005 04:56 PM
Changing Oil Ques. douGT 1996-2004 Mustang GT 14 05-01-2005 07:55 PM
Think changing your oil every 3k miles is good? Think again Monkey Pre-2005 V6 Mustang 14 02-24-2004 05:39 PM
06:45 AM
