02-19-2005, 04:31 PM
#1 | | Registered User
| Whats the difference between IRS and Live rear axel
Pretty much.... why do people always gripe about the cobra's having IRS? I know the IRS likes to break under hard drag launches but I don't know why. Can someone explain?
02-19-2005, 08:43 PM
#2 | | Registered User
The half shafts on the Cobra IRS are smaller than the single live axle on a GT. The trick is that the IRS in the cobra handles way better. The cobra is pretty much set up for the twisties, not a drag track.
__________________ 4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel |
02-19-2005, 09:13 PM
#3 | | Registered User
| Quote: |
Originally Posted by Horse The half shafts on the Cobra IRS are smaller than the single live axle on a GT. The trick is that the IRS in the cobra handles way better. The cobra is pretty much set up for the twisties, not a drag track. | Exactly how I came to understand it as well. The wheels tend to hop more with irs but when they're connected it makes it more difficult and gives you more traction.
__________________ |
02-20-2005, 04:24 PM
#4 | | Registered User
One is better for the drag strip, the live axle, and the other the IRS Cobra rears are for a road course. I have friends with Cobra's and they don't like the IRS to soft with the rubber bushings.
Matt
02-20-2005, 05:03 PM
#5 | | Registered User
I know that IRS doesn't seem to be as well on the drag strip. Which made me wonder why Ford would put it in the cobra. It seems that people are more interested in drag racing the cobra then road racing it. They should have added a live rear axel as an option.
02-20-2005, 05:16 PM
#6 | | Registered User
Ford wanted to be more of a road course stang.
Matt
02-20-2005, 05:34 PM
#7 | | Legacy Member
| Quote: |
Originally Posted by Eos I know that IRS doesn't seem to be as well on the drag strip. Which made me wonder why Ford would put it in the cobra. It seems that people are more interested in drag racing the cobra then road racing it. They should have added a live rear axel as an option. |
Drag racers by GT's because they are cheaper to buy and are going to mod it anyway.
Ford from the very beginning built the Cobra to compete with the european cars that are all set up as road course and better handling cars.
02-21-2005, 04:02 PM
#8 | | Terminator Owner
the IRS is nice for a smooth ride and handeling, but if you drag race an live axle is the only WAY to go, along with the fact that a live axle can be made to handle better than an IRS probably... you just pay for it dearly with extra noise and rough ride....
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
