air bag light blinking - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-01-2009, 08:13 PM   #1
jcl2669 is unknown around these parts
ok my air bag light is blinking a code 54 or 45 while it is running. it is a 93 5.0 with the 302 engine in it. any help will be appreciated.
jcl2669 is offline
Old 06-01-2009, 08:27 PM   #2
MonteCitan's Avatar
MonteCitan is unknown around these parts
Re: air bag light blinking
If its 45, I had this SAME exact code - LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
It ended up being the connector in the harness under the battery tray was corroding (tray was holding water/coolant from a leak I'd had and it was messing with the harness)
If you go to check it out, be sure to disconnect the battery and leave it disconnected for a while..
54 is : Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
Not sure where to start with that one if its 54..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
MonteCitan is offline
Old 06-01-2009, 08:58 PM   #3
thanks !!!!! anywhere i can get these codes for future reference ?
jcl2669 is offline
Old 06-01-2009, 10:07 PM   #4
bloodyspirit058's Avatar
bloodyspirit058 is unknown around these parts
Send a message via MSN to bloodyspirit058
im just curious, do both sensors need to activate to deploy the airbag? i would hate for that thing to go off randomly cause the sensor was either faulty or had correded wiring...
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline
Old 06-01-2009, 11:20 PM   #5
Otlaw80's Avatar
Otlaw80 is unknown around these parts
The light should flash a code a few times, then stay lit, showing the air bags are "shut off". Its basically a safety feature, if the computer finds a prob then it shuts them off as to not cause unwanted deployment.
Otlaw80 is offline
Old 06-01-2009, 11:47 PM   #6
MonteCitan's Avatar
You want to be careful with it, as - in theory - static charge can set off an airbag, but you should be fine with the battery disconnected
Airbag codes can be found Mustang 1995 Air Bag Diagnostic Codes <-- that's how I figured out my code when mine had the same issue..
Old 06-02-2009, 06:13 AM   #7
bbunt302's Avatar
bbunt302 is unknown around these parts
Mine flashes constantly because there are no airbags in the car. I wish I could figure out how to turn it off.
Scary stuff.
bbunt302 is offline
Old 06-02-2009, 08:22 AM   #8
MonteCitan's Avatar
bbunt, if your car is a 92..
I'm pretty sure the foxes used a one ohm resistor for the airbag simulators.. I remember checking one with an ohmmeter, it was pretty much right on the dot.. Head to radio shack and pick up a one ohm resistor, a bit of wire and I'm sure you could get it to work
You can also get the simulators that are used for diagnosis - rotunda tool # 105-00008
I think 93 is different (2 ohm?) and part # would be the same as the 94/95 systems - 105-00010
Old 06-06-2009, 04:46 PM   #9
here is what i copied from very useful.com web site
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open (See the Prolog)
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
jcl2669 is offline
Old 06-07-2009, 04:23 PM   #10
OsirisGuy's Avatar
OsirisGuy is unknown around these parts
EDIT: Never mind I just realized this was already resolved and you posting up the codes.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
OsirisGuy is offline
Old 01-13-2011, 11:50 PM   #11
94 Mustang GT's Avatar
94 Mustang GT is unknown around these parts
Yes both sensors need to activate to deploy, unless you induce voltage yourself! Even if you ohmed an airbag that could make it deploy!
94 Mustang GT is offline
Closed Thread
Air Bag beeping!!! jess93mustang 1979-1995 Mustang GT 5 09-07-2009 09:25 PM
Shutting off the air bag light? Otlaw80 1979-1995 Mustang GT 8 08-25-2009 12:06 PM
Air bag suspension. fasternu_674 Pre-2005 V6 Mustang 11 01-04-2008 05:49 PM
Flaming Bag of Poo Kiljosh The Bar 3 10-31-2007 04:13 PM
air bag light widowvirgin Pre-2005 V6 Mustang 7 07-19-2004 03:28 PM
08:05 PM
