i have a question - Mustang Evolution
Old 06-05-2009, 12:47 PM   #1
i have a question
i was thinking of putting in a ford racing 303x cam in my 93 gt, however i read that you must do alot of mods for that cam to work. does anyoe know what mods need to be done with that cam ?
93yellowgt is offline   Reply With Quote
Old 06-05-2009, 02:39 PM   #2
Re: i have a question
im not sure on the specs but the air flow and such have to match the came else its worthless
Old 06-05-2009, 03:08 PM   #3
what cam would you suggest?? i have 75mm into a trick flow street intake with gt40 heads and 30lb injectors
Old 06-05-2009, 05:19 PM   #4
bbunt302's Avatar
The X303 is WAY too big for that combo. It's meant more for a 347 stroker with AFR 185s or something similar. If you want an off-the-shelf cam, I'd recommend something like the Trick Flow Stage 1 or one of the smaller cams from the Comp Cams XE line.
Scary stuff.
Old 06-05-2009, 05:48 PM   #5
now would that mount up with my current set-up or would i need to make changes ?
Old 06-06-2009, 09:40 AM   #6
Mike90's Avatar
The cams he mentioned should work with your setup. I would just make sure you valve springs are within the specs recomended by the cam manufacturer.
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 06-06-2009, 08:53 PM   #7
thanks guys, i think i'm gonna go with the tf stage 1 cam. now the question is anyone need a 303x cam with about 1k miles on it
Old 06-07-2009, 09:28 AM   #8
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
i don't know alot about cams... but would the 303x be ok for a stroked 351? i need a starting place for my project
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-07-2009, 10:17 AM   #9
lol i'm not one to ask about Cams but let me know if you need it
thanks for the help one more question JAYS MUSTANG Pre-2005 V6 Mustang 3 09-16-2006 10:07 AM
Sub Question graystangguy06 Mustang Audio & Video 9 06-26-2005 12:56 PM
another 3.8-4.2 question. Horse Pre-2005 V6 Mustang 9 07-16-2004 09:37 PM
Question 98VroomVroom Mustang Audio & Video 1 03-28-2004 01:29 PM
Question 98VroomVroom Mustang Wheels & Tires 1 03-27-2004 10:20 AM
06:59 AM
