Found it! - Mustang Evolution
Old 06-10-2009, 07:35 PM   #1
Otlaw80's Avatar
Found it!
As my transmission saga continues. I recently came to the conclusion that my problem was the 1-2 shift accumulator. After reading about common problems with the aod-e and reading peoples personal problems they've experienced, and then finding a TSB about the accumulator sticking and breaking springs causing the transmission to just rev past 2nd gear and go into 3rd. Today at work i put her up on the hoist and took down the pan. Sure enough right there the seal for the accumulator was stuck at an angle in the bore causing fluid to bypass and not build up enough pressure to shift into 2nd. I tapped it straight and put a new snap ring in, along with changing the filter and flushing the trans. Seems to be working good now, but i ordered a new one from ford just in case it happens again. They redesigned them to stop this from happening. Crappy pics as i only had my phone with me, but you can see what happened
ID:	20733   Click image for larger version
Old 06-10-2009, 07:53 PM   #2
hottcobra's Avatar
Re: Found it!
congrats on fixing the problem with a little DIY
sometimes it's the little things that can give you the most hell.
Old 06-11-2009, 08:25 AM   #3
MonteCitan's Avatar
Re: Found it!
I love it when there's an easy fix!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-13-2011, 11:43 PM   #4
94 Mustang GT's Avatar
Re: Found it!
I had the same issue on my 96 4.6L Grand marquis! Drove it that way for 10,000 miles! lol
94 Mustang GT is offline   Reply With Quote
I think I have found my GT I am getting next Brent The Bar 29 02-09-2006 11:55 AM
I found it... bluemustang The Bar 11 04-25-2005 11:31 AM
HA! Look what I found! n8r The Bar 18 04-07-2005 08:55 PM
A little something I've found :) Rellik The Bar 13 12-04-2003 09:25 AM
Found a 98 Stang It was Sold but i found a White 97!! Black95GT The Bar 43 07-23-2003 08:34 AM
11:33 AM
