92 5.0 GT cutting CATS off....TRUE DUALS - Mustang Evolution
Old 06-17-2009, 09:00 AM   #1
I have a 5.0 with true dual............will cutting the cats off
hurt the engine at all..........i have been told you need the cats on
this engine for BACKPRESSURE..........
i want to cut them off to get a a better sound out of my flowmasters
that are on the car now.............and will cutting the CATS off
make it a little bit louder or do cats reduce NOISE at all?
i just got this car about 2 weeks ago and I LOVE IT
i just want it to rumble a little bit louder is all.
kneith is offline   Reply With Quote
Old 06-17-2009, 12:46 PM   #2
Re: 92 5.0 GT cutting CATS off....TRUE DUALS
it wont hurt but you will need to turn off the oxygen sensors as you will get a check engine light if you remove them. It will make the car louder. I recommend buying a off road H pipe and just bolt it on, you can then go back to your stock catted pipe if you ever need to.
Old 06-17-2009, 01:29 PM   #3
Herbstang's Avatar
What Brandon said you really don't want to run a V8 without a X or H pipe
Old 06-17-2009, 07:20 PM   #4
1234's Avatar
Isnt there an issue with equalizing cylinder pressure if you cut the X or H out of it.
Old 06-18-2009, 07:22 AM   #5
you need a balance pipe on a mustang V8 how ever it is, you technically I dont think HAVE to have one but its a bad idea not to
Old 06-19-2009, 06:04 AM   #6
bbunt302's Avatar
You don't need the cats. Losing them will also make the car louder. These guys are right about the balance pipe though. If you are running straight pipes, I'd really recommend buying either an H or X-pipe (or a Mac ProChamber, the best of both worlds).
The balance pipe actually increases exhaust flow by improving scavenging.
Scary stuff.
Old 06-19-2009, 09:53 AM   #7
edross's Avatar
your car will be twice as loud, at 80mph i cant hear myself think
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
99-04 v6 true duals (help!) CHILE10_STANG Pre-2005 V6 Mustang 14 06-22-2009 08:04 PM
how would true duals sound millastang Pre-2005 V6 Mustang 13 09-29-2007 11:01 PM
True Duals Taywi Classic Mustangs 10 12-09-2006 03:30 PM
cutting cats auto6banger Pre-2005 V6 Mustang 37 12-31-2004 11:17 AM
Time for True Duals 01mineralgrey6 Pre-2005 V6 Mustang 5 03-22-2004 07:59 AM
11:26 AM
